2000+ LD8 vs L37 - What's the diff?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 2000+ LD8 vs L37 - What's the diff? in Cadillac Engine Discussion; Just trying to sort out exactly what the difference is between the two on the newer N*'s. I've read around ...
    Rocket88 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Pontiac GXP
    Apr 2009
    Toronto, ON
    107
    I've read around here that there were some larger difference in 90's vintage N*'s, but haven't found a good listing of differences between the newer ones. I have heard that there is a different part number for the LD8 heads, but is that just related to cams? My understanding was that it was just a cams and tuning difference, but would like to know if I am right on this.
    Inquiring minds want to know!
    Thanks
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    Re: 2000+ LD8 vs L37 - What's the diff?
    As far as the mechanical parts of the engine its just the intake cams that are different. Tuning differences are done by the PCM.
    Apr 2009
    Toronto, ON
    107
    So the differnt part numbers for the complete heads would be just due to the different cams being in there, correct.
    So, if one overlooks the minor details of PCM tuning and final drives, then a LD8 could be turned into a L37 "simply" by swapping by swapping the cams?
    69
    82,383
    Yeah, but it won't run well due to the wrong final drive and PCM.
    Apr 2009
    Toronto, ON
    107
    Which is why I said if one "overlooks" those things...
    Actually, I have a Bonneville GXP, so I have the gearing part down already. Just need to do the PCM tune.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    49
    2,759
    I guess if you wanted to give up all that torque you could swap cams
    Apr 2009
    Toronto, ON
    107
    Not THAT much torque.
    I figure I am a couple of hundred pounds lighter than a STS, with the same gearing, so it shouldn't be too bad. The STS seems to pull pretty well.
    With the short gears in the GXP, you can certainly feel the power dropping off in the upper range of the tach. Ihe think the gearing on the GXP is a little short for the LD8. Maybe something in the 3.4 range would have worked better?
    That engine is so sweet, that it should pull smoothly and strongly to the redline.
  10. Remove Advertisements
