Help idntifying northstar engine!!
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Help idntifying northstar engine!! in Cadillac Engine Discussion; i just picked up a northstar, but im having trouble finding out what year its from. any help? numbers on ...
    guywithlegs is offline Cadillac Owners Member
    Automobile(s): 4.6 northstar
    Mar 2010
    1
    numbers on block:
    6RU605271
    3544850-1
    3522506
    Heads:
    22 93 8 B
    94 18 A 05
    On water crossover:
    3539786
    D1432
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,596
    Re: Help idntifying northstar engine!!
    If the 6RU605271 is off the machined pad on the side of the block below the right cylinder head then that's a "VIN derivative" and a GM dealer can run it to find out the VIN of the original car itself.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Build Date : 08/27/1993
    Eldo engine = LD8
    http://www.cadillacforums.com/forums...ain-parts.html
