Results 1 to 8 of 8
Thread: pcv valve
    Aug 2004
    Henderson, Ky.
    18
    pcv valve
    Where is the pcv valve located on the 2001 Deville and how do you get to it?
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: pcv valve
    It's on the valve cover of the rear cylinder bank on the passenger side. It sits in a rubber grommet and has a plastic hose running to it with a flexible rubber elbow connected to the valve. It just pulls right up out of the grommet. No tools necessary. This is a 10 second change. I'll try to post a photo if you're having trouble finding it and no one else has suggestions.
    Good luck...
    Mike
    LCLCLC is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville
    Mar 2004
    244
    Re: pcv valve
    Didn't someone on here say that starting about 2001 or so, there is no PCV valve? There is something like a pipe with just a restriction? Nothing to ever be changed?
  5. #4
    Jun 2003
    1,164
    Lightbulb Re: pcv valve
    That's a distinct possibility, but I don't know for sure. Anyone? Anyone? Bueller?
    Mike
  6. #5
    Aug 2004
    Henderson, Ky.
    18
    Re: pcv valve
    I looked all over the rear valve cover but didn't see it. Thanks for your effort though.
  7. #6
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    Re: pcv valve
    Quote Originally Posted by LCLCLC
    I think geno castellano mentioned that. It is just an orfice (permanent part of the engine)..
    No replacement needed or possible.
    Peteski
  8. #7
    Aug 2004
    Henderson, Ky.
    18
    Re: pcv valve
    thnx
  9. #8
    Jan 2003
    223
    Re: pcv valve
    Quote Originally Posted by CadiGeorge
    There is no PCV valve. Just the permanent, fixed orifice in the cam cover. The fixed orifice allows an onboard diagnostic for the PCV system as required by the onboard diagnostic requirements for the EPA. Eliminates one more thing to go wrong or service. If the system fails to perform correctly it will set a code.
  • You may not post replies
