2002 Eldorado rough idle
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, 2002 Eldorado rough idle in Cadillac Engine Discussion; My 02' Eldorado just started idling a little rough. It only had 55K. Do you think it could need plugs ...
    nascartamike's Avatar
    nascartamike is offline Cadillac Owners Member
    Automobile(s): 2002 Eldorado ETC
    Dec 2009
    Fort Hood, Texas
    51
    87
    My 02' Eldorado just started idling a little rough. It only had 55K. Do you think it could need plugs and wires this soon? There are no engine codes.
    68
    81,748
    Re: 2002 Eldorado rough idle
    Ripped plenum?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,554
    No wires - My '02 has 53K and is dead smooth.
    Start by checking the air filter, intake ducting, and the connector plenum between the throttlebody and intake manifold - the rubber thingy with the hose clamp around it - not the intake ducting, the intake side of the throttlebody - shoot a tad of choke or throttlebody cleaner down at the bottom of the rubber connector with the engine idling. Any leak there will show up as an idle speed increase.
    Here's what's inside/under your coil packs................click the pic
  5. #4
    Dec 2009
    Fort Hood, Texas
    51
    87
    Thanks. I will check tomorrow morning and let you know. What should the idle speed be? 800, 900, 1000 rpm?
  6. #5
    Skiller.'s Avatar
    Skiller. is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    650. Just below the 3rd hash mark (750).
  7. Remove Advertisements
