96 STS High Idle After Highway Run
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Northstar Engines and System Technical Discussion Discussion, 96 STS High Idle After Highway Run in Cadillac Engine Discussion; Our 96 STS runs normally around town but after 1/2 hr highway idles at 1200 to 1500. Seems like it ...
    Pete1996 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS, 1996 STS - RIP
    Aug 2009
    CT - USA
    197
    Our 96 STS runs normally around town but after 1/2 hr highway idles at 1200 to 1500. Seems like it will come down after shutting off and starting again. Is the computer confused? Not sure at all what is wrong.
    Replaced the plugs 6 months ago due to misfire, helped but not completely. Seems the mileage dropped before I changed the plugs. Used to get 20+ average, now getting 17. Driving it hard with WOT will bring on Service Engine light which then goes out after some normal driving. There were a few codes one being misfire. Car has 150K miles and does not overheat.
    Thanks for any tips!
    Skiller.'s Avatar
    Skiller. is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Re: 96 STS High Idle After Highway Run
    Did you replace the plugs with AC-Delco? What about the wires; how many miles are on them? I'm not positive about your high idle, but could have something to do with the throttle position sensor.
    Aug 2009
    CT - USA
    197
    I used #41-950 a few had the center electrode visibly off center. I was in a hurry and used them anyway.
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    You've got the right plugs in there then..and the wires?
    Aug 2009
    CT - USA
    197
    Didn't do the wires and probably should.
    68
    82,057
    Have you checked the FPR for a leak?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,197
    I'll bet the TB is in need of a cleaning also.
    High idle after road trips and a SES after WOT - any vacuum leaks anywhere?
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    carbon on the intake is my bet.. take off you air intake tube and check it out. i bet there is carbon in there causing it.
    Aug 2009
    CT - USA
    197
    Thanks everyone, I'm going to have to do some reading here since I don't have a lot of experience with the motor. Is there a thread on the best procedure for checking for vacuum leaks?
    Edit: I'll check FPR according to this thread: http://www.cadillacforums.com/forums...-pressure.html
    It does not have hot start issues.
    Edit: I'll try the TB cleaner to check for vacuum leaks: http://www.cadillacforums.com/forums...cuum-leak.html
    Edit: Cleaning the TB, 1998 close enough? http://www.cadillacforums.com/forums...ttle-body.html
    Aug 2009
    CT - USA
    197
    Pulled the codes:
    PC0139-HISTORY P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2
    PC1406-HISTORY P1406 - EGR Valve Pintle Position Circuit
    IR1771-HISTORY Could not find specific code Integrated Radio????
    On clearning codes it will go for 2 or 3 days without new codes, then the service
    engine light comes on, with new codes. Then days later it often goes off again.
    I believe that the electrical system is flaky, but am certainly open to suggestions.
    Some time after I changed the plugs I put Techron in it and about an hour later
    the service engine light came on. After the next fill up it went off.
    Aug 2009
    CT - USA
    197
    68
    82,057
    I'd start with the EGR valve.
    Aug 2009
    CT - USA
    197
    I will do that, thanks again!
    It seems like it runs better after clearing the codes, is it in some sort of fall back mode when a history code is set but the service engine light is off?
  16. #14
    68
    82,057
    Not sure, but I don't think so.
  17. #15
    Aug 2009
    CT - USA
    197
    Strange, it was doing the high idle thing consistently, now that I've cleared the codes it is not doing it since I've made two highway runs today. And as I said it seems to run better.
    I hope to get to cleaning the EGR ASAP.
  18. Remove Advertisements
