How do I get spark signal for chassis dyno
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, How do I get spark signal for chassis dyno in Cadillac Engine Discussion; I'm looking into have my car chassis dyno'd, but have come across an issue I haven't found a way to ...
    Kersh is offline Cadillac Owners Member
    Automobile(s): '05 Bonneville GXP/4.6L Northstar
    Jan 2010
    43
    4
    I'm looking into have my car chassis dyno'd, but have come across an issue I haven't found a way to solve.
    The dyno programming requires signal for cyl #1 for reference.
    Since the coils on my '05 Northstar are direct to the plug, there are no spark plug wires to connect the inductive pick-up for cyl #1 (or any other cylinder for that matter)
    Any ideas how do I get around this issue?
    Any info (regarding this) would be helpful.
    Thanks,
    Ken
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,248
    Re: How do I get spark signal for chassis dyno
    This may work: Your engine has COP coils, each held in by a Torx screw. Remove the beauty cover and expose the coil pack, #1 (passenger side, rear bank, first cylinder). Take a 10" length of #16 or #18 insulated wire with the ends stripped about 3/8". Wrap the wire around the coil form twice (the plastic/epoxy squarish thing) and connect the reference signal lead to the wire ends - twisted together. You have just made an inductive pickup coil.
    Jan 2010
    43
    4
    Thanks. I'll gave to give that a try with a timing light. If it works with the timing light, it should work for the dyno!
    Ken
    Feb 2006
    56,248
    If your timing light uses an inductive ferrite clip - around a plug wire - try laying the tip flat on the coil top epoxy first.
  7. Remove Advertisements
