Oil Usage with Synthetic Vs. Mineral
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Northstar Engines and System Technical Discussion Discussion, Oil Usage with Synthetic Vs. Mineral in Cadillac Engine Discussion; To start, I have a '94 Northstar that has about 111,000 miles on it. Runs great, plenty powerful and has ...
    ryangmann is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac DeVille Concours 4.6 Northstar
    Oct 2009
    Newark, OH
    29
    18
    To start, I have a '94 Northstar that has about 111,000 miles on it. Runs great, plenty powerful and has experience no issues.
    My question is about its use of oil. I run Valvoline's Max-Life full synthetic
    10W-40 and my engine seems to burn a bit of oil on a regular basis. I have heard of people with northstars having the same issue, and switching to mineral oil, only to have it not burn or use a single drop once the switch is made.
    This puts me in a strange situation. I want to take good care of my engine with quality lubricant, so I use fully syntetic oils. Yet, if the engine simply doesn't burn or use mineral oils, is it really worth the switch?
    Does anyone have any experience with this issue?
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Re: Oil Usage with Synthetic Vs. Mineral
    do you use 40w to reduce oil use or do you think you have worn bearings and heavier oil helps maintain oil pressure? do you get any oil light flicker at idle? just wondering why you don't use 10w-30? 111k miles is hardly worn out.
    Oct 2009
    Newark, OH
    29
    18
    Well, I've been using 40w for the heavier weight to reduce the amount that is burned off. I have only seen my "check oil level" message once, since I keep a close eye on it.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,822
    If your engine uses oil with synthetic, it will use oil with good ol' dino. Just how much is a "bit" of oil, usage-wise ?? 1 quart every 1,000, 2,000, 3,000 miles ??
    At the risk of perpetuating yet another oil war, your engine will live long and prosper on any name brand of oil, dino or synthetic, 10W-30 or 10W-40, but I would advise against running 10W-40 if the temps are frequently much below 32 in the winter at your location. (Your Northstar was NOT spec'd for 10W-40)
    Go back a little bit in here and up in Seville, find the recent synthetic and dino oil threads, and open the links to oil discussions and filters. Lots of good info.
    Remember that motor oil is exactly like whiskey and women: everyone has their particular preference, and logic seldom enters into the equation.
    Oct 2009
    Newark, OH
    29
    18
    Honestly, I haven't kept track of how much exactly. I would say 1 qt every 1500-2000 miles....Like I said, it's pretty small.
    Haha I like your quote there too...."Remember that motor oil is exactly like whiskey and women: everyone has their particular preference, and logic seldom enters into the equation." Well said
    Feb 2006
    56,822
    A quart every 1500-2000 is right smack in the middle of the GM "desired" consumption bell curve.
    Some Northstars use a quart every 1000, some use a quart every 4,000.
    My engine uses a quart every 4,500 and I use Pennzoil 5W-30 Platinum synthetic and a WIX 51522 filter. I changed the oil/filter on 03-22-09, added 28 ounces during the year, and just changed it again on 03-06-10. The oil had 6,700 miles on it and drained as a clear, dark amber color. This change will be fine until next year.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    4,500 miles/quart in a Northstar is excellent Sub - that's the best I have heard. Mine have all (I just added them up in my head - wow - I've had six!) been in the 1,500-2,000 range, which is fine with me.
    Feb 2006
    56,822
    After joining CF back in 02/06 I started reading and thought "Is this car an oil burner ?", so I started a pretty faithful work log which is kept up to date. Every gallon of gasoline, oil, coolant, and wax used on this car to date is documented. It gets driven hard, not abused, kept clean, and if something goes wrong that arthritic hands don't feel like fixing, it goes to Fitzgerald Cadillac in Annapolis. Other than normal maintenance (OnStar upgrade, tires, wiper blades, exterior light bulbs, transmission fluid, coolant, brake fluid and power steering fluid exchanges) and toys (CORSA, strut brace and a set of EBC Black Dash rotors and Redstuff pads) the car has cost exactly $0 in repairs since 11-05. Yes, the car has only 53,000 miles, and yes, it will eventually need stuff like struts, shocks, CV joints, you name it. I like the car enough that when that time comes it will get the best of everything.
    Some of us got lucky, and there are hundreds of thousands of Cadillacs running around every day that see the inside of a dealership maybe once a year and that's IT. (My Ford truck is another example of a trouble-free vehicle.)
    69
    82,265
    My '97 used a qt/1500. My '03 is close to Subs I think. Not positive, but I think GM may have made some changes in 2000 that reduced usage.
    jcresciSTS is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Cadillac Seville STS (November 2012, 183k)
    Jul 2009
    South San Francisco, CA
    29
    968
    Just to be clear you are only filling it up to halfway up between the min and max, right?
    The max is 8qts and if that's what you fill up to it will burn up the excess and cause you to think you are burning oil
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    Quote Originally Posted by submariner409 View Post
    Wait for the front end to fall apart on you with Ford's awesome high quality ball joints and tie rod ends with no grease zerks!!!
    Feb 2006
    56,822
    I've gone through three F150's (this one is my fourth) and the first three went to over 130,000 each with no front end work and this one is at 70,000 and is tight as a drum. Not a problem.
    My 2002 STS has no Zerks and it's just fine also.
    Oct 2004
    Oak Creek, WI
    5,607
    hahaha, yeah sorry man, had to express my hatred for ford truck/panther suspension setup. Lots of vehicles make it through ownership without front end work, especially if it's sold as young as 130,000. And unfortunately, like you suggested, in recent years the absence of grease zerks has become more common.
    Had 2 trucks and one Grand Marquis at the house last year needing an assortment of front end work. On one ('01 F150 4x4), the lower ball joint was so bad it actually separated while the owner was moving, steering knuckle swung out, ripped the axle shaft out of the front diff, and the truck "fell"!!! No fun for me...
    As far as front end problems, I get more business out of Ford vehicles than any other manufacturer
    On the other hand, I have 3 170,000 mile Cads and one 160,000 mile Cutlass Supreme in the driveway, regularly greased, on original joints.
    GREASE ZERKS FTW!
  16. #14
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Quote Originally Posted by jcresciSTS View Post
    Yes - no higher than halfway between min and max. Also, had to add a quart to the 2000 DTS yesterday - around 1,800 miles since it was changed. I'm not complaining, mind you.
  17. #15
    Oct 2009
    Newark, OH
    29
    18
    Well thanks guys, this does help. I was worried that mine had some unforseen issue but I'm glad that oil usage is normal in these engines.
  18. Remove Advertisements
