Normal Compression on a correctly timed 1996 N*
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Normal Compression on a correctly timed 1996 N* in Cadillac Engine Discussion; Does anyone have an idea on what normal compression is for a correctly timed 96-99 Northstar engine when tested with ...
    IXSLR8 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    69
    Does anyone have an idea on what normal compression is for a correctly timed 96-99 Northstar engine when tested with a compression gauge?
    General Engine Specs: Heads were done at a shop. The shop said they were beautiful before they did any fine tuning on them. I strapped them down with studs, inserts and Cometic gaskets. Engine has approximately 50K on it.
    Context: I'm currently working on a N* in another vehicle and am trying to determine if my compression indicates that I'm out of time by a tooth on my intermediate shaft to crank chain. I keep getting a PO300 code stating random misfiring and I've replaced all engine sensors, wires, coil packs, plugs, etc...:
    Compression test (Cranked Over for 5 seconds):
    1-145 lbs.
    2-150 lbs.
    3-150 lbs.
    4-150 lbs.
    5-150 lbs.
    6-150 lbs.
    7-150 lbs.
    8-170 lbs.
    Second Test (while running):
    1--75 lbs.
    2--80 lbs.
    3--83 lbs.
    4--80 lbs.
    5--80 lbs.
    6--83 lbs.
    7--85 lbs.
    8--83 lbs.
    Any thoughts are appreciated. Thank you, Dave.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    Re: Normal Compression on a correctly timed 1996 N*
    The 150 psi group is perfect. The 170 is high (carbon ???)
    I have never done a running compression test and see no need for one.
    The guideline is that all cylinders should be within 10% of the mean - you're still in the ballpark.
    Are the coils/plugs connected exactly as shown in the diagrams ? That's critical to prevent a nagging miss.
    Click on the diagrams to enlarge.
    Mar 2008
    69
    Thanks Sub. for your help.
    I thought the compression looked pretty normal except for the high number 8 cylinder. I was thinking carbon too.
    I'm very sure that I timed the motor, as per the posted diagrams, when I did the block inserts and such. I was hoping to see if my compression readings, as compared to someone elses correctly timed northstar, would tell me anything about my timing. This is the first time I have done a running compression test. Someone mentioned to do that kind of reading as well.
    I was thinking that I may be off a single tooth on my counter balance shaft to crank sprocket but have the cam chains correct. I have a mild misfire and get the P0300 code as mentioned. I've replaced just about everything I can think of and am now second guessing the timing work I did.
    Once again, thank you sir.
    Feb 2006
    55,904
    Hmmmmm.........Call Jake up in Canada at Northstar Performance - www.northstarperformance.com
    or go back and find some posts by MikeLawson - he does some Northstar work out near Lexington, KY.
    68
    81,922
    If I recall correctly it is pretty easy to get the Northstar timing off by a tooth. I remember our old Guru mentioning something about rotating the crank 7 times to get it back in sync or something like that.
  8. Remove Advertisements
