Fluid Change vs Fluid Flush...
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Fluid Change vs Fluid Flush... in Cadillac Engine Discussion; Well, this has turned out to be a major dilemma... I would like to get some new coolant, and new ...
    Skiller.'s Avatar
    Skiller. is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    I would like to get some new coolant, and new transmission fluid (DEXRON VI) in my car.
    It seems like the only thing shops offer is a FLUSH, and as Ranger says, "flushing is for toilets", and I'd have to agree.
    Who knows when they clean those machines.
    Anyway, I'd just like to know what my options are for getting this done.
    Thanks!
    68
    82,082
    Re: Fluid Change vs Fluid Flush...
    Short of doing it yourself, most dealers do an "exchange". An exchange is basically a flush (not reverse flush) with the appropriate fluid. In other words, they pump new fluid in until all the old fluid is expelled. THAT I could live with and you know that they know (or should know) what they are doing.
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    So it would be ideal to just drain it, and refill it?
    Take a look at these two links in regards to coolant and transmission.
    This isn't the normal dealership I bring my car to, but I'm sure all GM dealers offer the same.
    Coolant: http://www.jimball.com/CoolantExchange.html
    Transmission: http://www.jimball.com/TransmissionFluidExchange.html
    They offer a coolant drain/refill, as well as a flush.
    As far as the transmission goes, it doesn't look like they offer just a drain/refill. Like you said, it's an exchange.
    If I were to get the bare minimum for each, would that be plenty sufficient?
    68
    82,082
    Bare minimum should be sufficient.
  7. Remove Advertisements
