Dowel Problem!
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Dowel Problem! in Cadillac Engine Discussion; I really messed up one of the dowels....Did that old trick by putting in one of the chain guide bolts ...
    malibuandryan is offline Cadillac Owners Fanatic
    Automobile(s): 97 Deville Concours and 2000 STS both with NP studs
    Jan 2007
    INDIANA
    110
    Dowel Problem!
    I really messed up one of the dowels....Did that old trick by putting in one of the chain guide bolts and clamped down on it......bad, bad idea.....I really don't have any dowel to grab now.....Can I use the bit that came with this stud kit, and drill out the bad dowel (very carefully)???..if not what do I do?..The other three are getting removed the right way for shure!............................By the way, I have a few holes drilled and tapped and ready to go!!....It's working great!!..Ryan
    1997 Deville Concours
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    Re: Dowel Problem!
    That dowel has to be out completely. The 17/32 bit will remove a little bit of the alignment pin but there will still be a thin shell left. It has to come out.
    My advice would be to first drill out what you can, using the fixture plate of course, and then cut down the side of the dowel with a very sharp, small chisel. Very carefully. Then using a very small flat tipped screw driver, pry out what's left.
    Good luck
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Dowel Problem!
    Quote Originally Posted by 97EldoCoupe View Post
    Good luck
    I'll add that if you slightly damage the side of the hole that the dowel seats against it won't hurt anything. That is only the side of the hole only, be very careful not to damage the top of the block.
    The side the dowel is going to seat against the side and the side doesn't seal anything, the top of the block does the sealing.
    Jan 2007
    INDIANA
    110
    Re: Dowel Problem!
    Got the dowels out!....I ended up welding a bolt to the three remaining dowels and out they came!...worked like a charm!.....Thanks for the help.....Ryan
    Mar 2007
    31
    2,618
    Re: Dowel Problem!
    I'm glad it worked for you!
    - those pins can be a real pain....
  8. Remove Advertisements
