CARFAX (engine / car serial Numbers)
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, CARFAX (engine / car serial Numbers) in Cadillac Engine Discussion; I am in the process of having a used northstar installed in my 96 sts, A member of this group ...
    scottm is offline Cadillac Owners Member
    Aug 2004
    38
    I am in the process of having a used northstar installed in my 96 sts, A member of this group recommended running a carfax report on the engine which I think is a good idea. But im not sure if the serial numbers carfax asks for are the same as the serial numbers on the block,. Do serial numbers on the block match the ones on the car it came in?
    scott m
    Aug 2004
    38
    Re: CARFAX (engine / car serial Numbers)
    does anyone know if the serial number on the engine is a 17 digit number?
    scott
    Marshall is offline Cadillac Owners Member
    Jul 2004
    Tehachapi, Ca.
    62
    12
    The engine s/n will be a 9 digit/letter combo.The last 8 will match the last 8 of the car's vin number. At least it did on mine.Hope this helps.
    Marshall
