Water pump tensioner pulley replaced
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Water pump tensioner pulley replaced in Cadillac Engine Discussion; I'd been hearing a very high pitch noise for about 5 seconds when started in the cold. I thought maybe ...
    derone is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac STS
    Aug 2007
    NC
    133
    I'd been hearing a very high pitch noise for about 5 seconds when started in the cold. I thought maybe it was the Bose sound system at first and later started listening under the hood. I could hear a little crunching noise around the water pump only when cold. Pulled the belt cover, then the belt and the little pulley was tough to turn. Water pump turns easily. JThe car just turned 100k miles. Found just the new pulley locally for $40 at Carquest. A Gates part #38025. It's not a hard job to replace it; I'm glad I found out what it was, while in the driveway.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    Re: Water pump tensioner pulley replaced
    Good catch, BUT others in our same year group with a high-pitched whine from the engine room at cold start may be hearing the A.I.R. compressor feeding fresh air to the exhaust manifolds in order to light off the cat...........................
    Aug 2007
    NC
    133
    True that, it sounded more like a schrill noise and it wasn't consistent like the AIR emissions pump(s).
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    I just started hearing this the last few mornings on the ETC - very high pitched squeak. It is only for the first 20-30 seconds, and it is intermittent. I got out and looked the first AM, and it seemed to be coming from the water pump area. I assumed it was a worn, dried out tensioner pulley bearing. I planned on changing it out this weekend. I checked it out again this AM, and was amazed to see that the squeaking was not coming from the bearing - the squeak was from the BELT slipping over the tensioner pulley! Wild and crazy stuff! I could see stationary tensioner pulley, apparently with a locked up bearing, and the drive belt slipping over it, making a really loud squeaking sound. After about 20-30 seconds, the pulley started to turn and the sound went away, never to come back the rest of the day.
    Anyway, needless to say, the pulley, and/ tensioner is getting replaced this weekend as planned.
    Feb 2006
    56,582
    Make an offering to the Northstar gods - that tensioner pulley could have stranded you in Possum Trot, Tennessee. As an aside, I'll bet the tensioner spring/swing arm is locked so there's actually very little "tension" on the belt itself........change the belt, too.
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by submariner409 View Post
    Yep - that's why it's important to listen and pay attention to unusual sounds coming from your car
  9. Remove Advertisements
