Advice on engine teardown TOMORROW
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Advice on engine teardown TOMORROW in Cadillac Engine Discussion; Hey, So thanks to the advice on the site I will have the engine dropped tomorrow morning. Total time 6 ...
    bigds01 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Seville SLS
    Nov 2009
    137
    Hey,
    So thanks to the advice on the site I will have the engine dropped tomorrow morning. Total time 6 hours (there were 3 of us).
    We want to get the hg job done tomorrow. Should I just follow the teardown directions in the service manual? Other then the pully puller, and the waterpump tool are they any (and I mean ANY) other special tools I should have (torque guide?)?
    Any advice would really help.
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    Re: Advice on engine teardown TOMORROW
    i thought you were doing this in 2 days about a month ago?? (ya so did i LOL)
    i cant comment on the top of the engine, but if you need a new rear main, that does not require a tool, it just pushes in.
    my crank pully came right off even with a cheap 3 jaw puller, reused front cover gasket and front main (still really soft)
    i dont think you are pulling the pan or half case right?? if you do the EN alignment pins do actually work quite well.
    the problem is when you find parts that arnt stocked anywhere, then you have to wait.
    thats all i know, good luck!!
    YueIBM is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS 226,000 miles, XC90 V8
    Dec 2009
    Ann Arbor, MI
    19
    You might want to get some tough PVC pipes that go over your ratchets / wrenches, to get enough torque on the cam sprocket bolts. They were very difficult for me to remove even after turning my wrenches into 3-foot breaker bars with the pipes.
    Be sure you and the other person coordinate well, or rest the camshaft wrench on a solid surface to avoid stretching or breaking the chains as you take off the big cam sprocket bolt.
    Also, do you have fuel line disconnects? ...unless you plan to hang the intake under the hood.
    Good quality tools are invaluable. I rounded out two 10mm sockets before I bought a Craftsman one that didn't even get nicked.
    Good luck!!!
    Nov 2009
    137
    We actually didn't start on the engine until last week. We spent a day doing the brakes first.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by YueIBM View Post
    Good luck!!!
    Camshaft drive sprocket bolts were easy for me to remove - I think they are only tightened to around 75-90 ft pounds. Remember, there is a hex cast into the cam to fit an open end wrench on to hold the cam.
    The bolt that was REALLY hard for me to get off was the crankshaft pulley/harmonic balancer bolt - that was the one that required a 2 foot breaker bar with 3 foot pipe on it!
    Nov 2009
    137
    We applied a little heat to the harmonic bolt, 2' breaker bar, and two fat asses (I was one), took about 5 minutes to crack it.
    buggin123 is offline Cadillac Owners Member
    Automobile(s): 1998 seville
    Nov 2009
    45
    27
    I wonder if anyone else uses an impact wrench to pull fastners when breaking down an engine?
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    I used an Ingersoll Rand impact wrench with no success. I also used one fat ass (mine), but I guess the secret is to get two fat asses - the other ass helping me at the time was a skinny melink
    Nov 2009
    137
    Quote Originally Posted by tateos View Post
    We used your idea to heat up the bolt for a second. 500 pounds of lard later, it broke quickly
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    my ingersol 1000ft lb impact took the crank pully bolt right out with about 10 hits on it.
  13. Remove Advertisements
