4.6 Northstar
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Northstar Engines and System Technical Discussion Discussion, 4.6 Northstar in Cadillac Engine Discussion; People, I am doing my irst Northstar head gaskets. So far so good, but the Haynes manual was a waste ...
    dtino is offline Cadillac Owners Member
    Automobile(s): 85 2dr Fleetwood & 02 DTS
    Jan 2010
    60
    85
    4.6 Northstar
    People, I am doing my irst Northstar head gaskets. So far so good, but the Haynes manual was a waste of money of the this issue. I found the tightening specs, but I need to get the tightening sequence. Can someone help here? I have a 94 Seville SLS which I really like and want back on the road asap, any help would be GREATLY appreciated.
    Thanks, Dave
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,264
    Re: 4.6 Northstar
    Chilton's and Haynes are useless - far too generic.
    For your needs, right now, subscribe your car to www.alldatadiy.com - GM service manual as well as rate, labor, recall, warranty, Technical Service bulletins, more info than you can ever read for your particular car.
    Otherwise, the GM manual comes from www.helminc.com or eBay.
    Here's the torque sequence BUT there's a very specific method of setting starting torque and then three additional passes of a certain number of degrees of bolt rotation - there is not a final torque value.
    Jan 2010
    60
    85
    Re: 4.6 Northstar
    Thank you, Thank you! Now if I can ask one more question, which service manual do I need to get? I look at your link and they are showing two, Shop\Service Info and one that they are calling a supplement. I will order right away, I need my car back as soon as I get it back together now that my older caddy is acting up.
    Thanks, dtino
    Feb 2006
    56,264
    Re: 4.6 Northstar
    I'm spending your $$$, but if you are looking at Helm, Inc. manuals OR Alldata I would order the manual and supplement - there are always running corrections published.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: 4.6 Northstar
    The 94 year has 2 Service manuals. 1 for chassis and drivetrain and the other for electronics. Guess which one is fatter.
    Jan 2010
    60
    85
    Re: 4.6 Northstar
    First of all, THANK ALL OF YOU!! Everyone has been a lot of help in this new journey. I have one last question before I get deeper into this Northstar, does the intake have also have a sequence as to the tightening? Haynes show the sequence for the service cover, what about the intake itself?
    Thanks, dtino
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: 4.6 Northstar
    Are you planning on dropping the engine or are you going to try it in the car?
    Here's a thread I did after doing one. There are other good threads that I lost links to so you will have to search (do an advanced search). The one by Tateos has a lot of tips in it.
    http://www.cadillacforums.com/forums...ir-part-i.html
    Jan 2010
    60
    85
    Re: 4.6 Northstar
    Thanks!, I am doing the head job while the engine is in the car. So far so good and it is coming apart fairly easy. It helps to have small hands. I hope to be done by the end of the month, I have to work and only get to do the car on weekends. I will be nice to be able to drive her again. My 85 Fleetwood has lasted me 25 years without any problems, I was hoping to get the same out of the 94, but things happen. I have to put in a heater core due to the overheating (engine found a weak spot), it looks like that job is going to be harder than the head gaskets! Many thnks to all of you.
    dtino
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: 4.6 Northstar
    On the 94 there are only four 8mm bolts holding the intake manifold down. The tightening sequence is not critical, but I usually go in a criss-cross pattern.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Re: 4.6 Northstar
    I would not trust AllData for torque specs. They're a great reference resource but I'd go with a FSM for that type of project. I've found AllData to be wrongs about torque specs on a few different occasions.
    Sep 2003
    Arizona
    3,531
    Re: 4.6 Northstar
    Only a few people have sucessfully done it in the car because that is by far the hardest way to do it. Bigtony (not sure if that's correct ID) is the only guy who said it wasn't bad.
    Here's Tateos's thread: http://www.cadillacforums.com/forums...t-project.html
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Re: 4.6 Northstar
    Wait, I'm confused. Does the 94 SLS have a N*? I thought that was 4.9 till 95 or 96.
    Well, apparently it does if you're asking so yes, doing that job in the car is a last resort ditch effort from what I understand.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: 4.6 Northstar
    Not positive, but I think in '94: Seville and Eldorado got N* in both trim levels - Deville was the one that had 4.9L in Deville, N* in Concours trim. Fleetwood was 5.7L
  16. #14
    Jan 2010
    60
    85
    Re: 4.6 Northstar
    I have found that the N* also was in the 93, I have found some used manuals for a 93 and am going to see what the differents is in the 93 and 94. So far doing the HG's in the car isn't hard at all, but of course my hands are thin and small and I am able to get to bolts most people can't. I was surprised at how easy the water pump was. The only hard part is getting the gas lines apart! And what were they thinking with the starter? LOL LOL I enjoy learning about this N*, I am a caddy man all the way and really want this N* to come out right. I have had my Fleetwood for 25 years and it has never failed to start (of course I am the only one that works on it). After the SLS is done I am doing a total restore on the 85 . I will have both car till I am gone.
  17. #15
    Jan 2010
    60
    85
    Re: 4.6 Northstar
    Well I am updating my travels with my N*. So far I am down to taking the valve covers off, and it has been fairly easy to this point. I am not rushing it, I want this to be a good learning tool too. I have been looking things over as I am working on it, I hope to have her done by the end o this month. I will post more as I go along, again many thanks to everyone that has helped me along the way.
  18. Remove Advertisements
