160* Thermostat?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 160* Thermostat? in Cadillac Engine Discussion; I put 160* thermostats in my other cars with great results. I've heard the N* is supposed to run hot. ...
    AlanSr is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Oct 2009
    6
    160* Thermostat?
    I've heard the N* is supposed to run hot. Would a 160 help my wife's 2001 Deville?
    Or would the engine temps be too low?
    68
    81,751
    Re: 160* Thermostat?
    No. Use the stat that is spec'd. I believe it's a 190 or 200. Sub will probably know for sure. A 160 will run it way too cool.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,560
    Your OEM thermostat is set to begin opening at 188 and fully open at 206. The engine sensors are all calibrated to "assume" a running temperature of about 195-200 degrees. Your cooling fans run in slow whenever any A/C function is set, and if the A/C is turned OFF fans go to SLOW at 224 degrees and FAST at 236 degrees.
    A 160 degree thermostat forces the sensors to compensate for a "low temperature" engine fault which gives longer cat lightoff times, slightly richer fuel mixtures and cool oil (which is detrimental to efficiency and oil cleansing through evaporation of contaminants/acids).
    The Northstar does not run hot. It runs right in the design temperature band, and if we had better coolants, engines would benefit from running up in the 225-240 degree range due to higher efficiency.
    Click the pic to enlarge and see where the engine is running with the gauge at 12:00, its normal reading. In heavy traffic a Northstar FWD will easily go to 225 and back down as the fans cycle.
  5. #4
    Oct 2009
    6
    Thanks guys!
    I'm glad I asked first.
  6. Remove Advertisements
