Coolant manifold/Crossover gasket sources?
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Coolant manifold/Crossover gasket sources? in Cadillac Engine Discussion; Any one have any thoughts on where to buy the gaskets for coolant manifold/crossover. I can get them with top ...
    buggin123 is offline Cadillac Owners Member
    Automobile(s): 1998 seville
    Nov 2009
    45
    27
    Any one have any thoughts on where to buy the gaskets for coolant manifold/crossover. I can get them with top end kit, but have not been able to locate aftermarket source. Or perhaps the GM p/n? I have tried to find on GMpartsdirect and cannot find. Thanks
    ejguillot's Avatar
    ejguillot is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    Jul 2006
    Tampa FL
    42
    985
    Re: Coolant manifold/Crossover gasket sources?
    Rock Auto (rockauto.com) should be able to supply all the gaskets you need. That's where I got mine from...
    Nov 2009
    45
    27
    I tried there but maybe I am not looking for the right thing? I looked under engine parts and coolant system parts and can't find these gaskets. Anyone know what there called?
    69
    82,377
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Rockauto.com under cooling system --> water pump gaskets
    bigblockolds is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Nov 2009
    8
    Fel-Pro numbers:
    Upper: 35656
    Lower: 35658
    Part numbers are for individual gaskets, so you'll need a pair of each.
  9. Remove Advertisements
