intake manifold bolt torque?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, intake manifold bolt torque? in Cadillac Engine Discussion; Quick question for those of you who've got a manual for 95-99's... I need the specs for the manifold bolt ...
    Feb 2004
    FL
    2,250
    Quick question for those of you who've got a manual for 95-99's... I need the specs for the manifold bolt torque. It's probably on the order of like 6ft lbs, but I don't want to guess. Thanks in advance!
    maydog's Avatar
    maydog is offline Cadillac Owners Fanatic
    Jan 2003
    Minnesota
    319
    Re: intake manifold bolt torque?
    it is 89 lb-in (7.5 lb-ft) for a 97. Use care with these bolts, I snapped one off in the head with little torque.
    Feb 2004
    FL
    2,250
    Thanks much! How did you end up snapping one?
    maydog's Avatar
    Jan 2003
    Minnesota
    319
    I used a torque wrench that oinly went down to 10 foor pounds and tried to set it lower. I was lucky enough to be able to back the bolt out with a chisel whe I changed my starter.
    RWalesa is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Deville Concours
    May 2010
    52
    Forget torquing it to 7.5 ft-lbs. Do it by hand. I used a torque wench at 6 ft-lbs and snapped the bolt, added 1.5 hours to the project. If you are going to do it, do the front and center one, it is easier to drill out. 1997 Devill Concours w/ Northstar.
    68
    81,926
    I think the OP finished the job seeing as this thread is 7 years old.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,998
    For the future reference: Use an inch pound torque wrench. Or use hand carefully, and don't go torque crazy. It doesn't have to be THAT tight..
  10. Remove Advertisements
