pull tranny, fix half case leak
Page 1 of 9 123456789 LastLast
Results 1 to 15 of 122
Northstar Engines and System Technical Discussion Discussion, pull tranny, fix half case leak in Cadillac Engine Discussion; guess ill try this section, hope to get some response... Heres the tranny part of it. http://www.cadillacforums.com/forums...n-leaking.html Ok, im ok ...
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    Ok, im ok with having to pay $600 to R & R the tranny......
    but my half case leaks like a sieve, add 3 quarts between oil changes, and i dont think its burnin any of it....
    Now i just put together a stroker motor for my jeep (made my 4.0 a 4.6L)
    Im wondering if i pull both trans and engine if its possible that i could do the half case??
    Or is there so many special tools and knowledge it will make it impossible for me?
    I figure if im fixiing the tranny, i might as well save the tranny labor and do both myself.....
    Or pull both and have someone fix the half case
    Thought please, i need to get a car back
    Read the half case thread in the tech tips section now.....
    that really doesnt look that bad??
    So i wouldnt be messign with the crank or anything.....or are the bearing in that half case?
    What do you all need to buy (looks like alignment tool for sure) and cost to due this?
    That might be an easy thing to do if the engine is already out.......
    ah....so it looks like the half case is one complete main bearing cap so to speak....im still ok with that...
    Where can i buy these alignment pins and the oil plate you have to get??
    What else do i need to do this, i thought i saw somewhere about a puller for the crank pully? Someone said to not use a 3 jaw, one other said the manual says to use 3 jaw, yet another stil couldnt get it off anyway??
    I have the service manual, and plan on using the half case thread in the tech tips.
    Just need to know the cost of parts and tools and anything else i need like the oil passage plate?
    ejguillot's Avatar
    ejguillot is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    Jul 2006
    Tampa FL
    42
    985
    Re: pull tranny, fix half case leak
    cl1986,
    read my thread (I'm doing everything you're doing):
    http://www.cadillacforums.com/forums...eadgasket.html
    If you can pull the tranny, you can pull the engine. Your half case reseal procedure will be different than mine.
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    ok, ya i already read your thread, but you didnt mention anything yet on the half case....
    did you buy the stuff yet for it?? The gm silicon, the oil dist plate, and i assume new oil pan gasket.....then the EN tools? anything else?
    why would my half case be different than yours?? the tech guide shows both our years on it??
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Thumbs upRe: pull tranny, fix half case leak
    That leaking trans is unusual - better investigate further before you pull it, maybe unnecessarily...unless maybe you are looking for a project? If so, in your situation, I would drop the cradle, get the trans rebuilt, get a new torque converter, do the half case and oil pan reseal, and do the HG repair while you're at it.
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    im trying to investigate.......no one has any answers...
    and why would i do a headgasket repair when they are fine??
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Get a second or third opinion regarding the trans leak - if they suspect a crack in the bellhousing area, they should be able to see it with the trans still in the car, even if they have to use a scope to see it.
    Head gasket failure is a common problem that requires removal of the engine - usually by dropping the cradle. Once you have removed the cradle from the car. and the engine and trans from the cradle, the hard part is done. Why not do the HG thread repair and coolant crossover repair (replace the gaskets/seals) at that point, and be assured of many miles of worry free ownership? That's what I would do; otherwise, just R and R the trans, and leave the rest in the car. Adding 3 quarts between changes is pretty normal for a Northstar, and it's a lot easier and cheaper than replacing the half case, oil pan gasket, and rear main seal, which BTW could all be the source of your leak. You could do just the rear seal and leave the engine in the car, if you just do the trans.
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    well im not doing headgaskets when i dont need to....probrably never will have to with this motor.....only a very small percentage of N* have headgasket problems....
    try this one....coat your garage floor with epoxy, then pour out 3 quarts of oil on it and see what kind of mess it is......should cover at least one whole stall
    if you know its a lot cheaper than replacin the half case......thats my frickin question!!!! If im pulling the trans, it isnt much more work to pull the engine, so the extra little effort is all im worried about.....but i want to know the cost to fix the half case seal (parts and tools $$$)
    Thanks
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    so just pull them out?? Dont worry about the cost of fixing the half case??
    Will be starting tomorrow, was hoping someone had some info.....
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    You already know everything.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    You keep asking for the price of a half case seal...look up the parts. Ii haven't done one and most of the guys haven't either. I've done several HG's but I can't tell you what it will cost you to buy whatever you don't have.
    We're glad to offer what help/advice we can but we don't know everything. A factory manual would be a great help for you, even if it's a year or two off. I did my first HG's with a 98 manual.
    You are right on the HG's. If you have no symptoms why do that big of a job.
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    well its just a simple questions, these guys have the parts laying right there, they are doing it or have done it, so it shouldnt be that hard, didnt know it was that big of a deal usually people know how much the parts cost them and not just start buying stuff, what if an oil passge plate is $1000?
    ill price it out myself i guess, no better place to get these parts from? Thats all im asking.
    buggin123 is offline Cadillac Owners Member
    Automobile(s): 1998 seville
    Nov 2009
    45
    27
    Go check out Rock Auto.com, They seem to have the lowest pricing.
    Sep 2003
    Arizona
    3,531
    start with rockauto.com or gmpartsdirect.com
  16. #14
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    This is how the FSM says to remove the crankshaft pulley:
    Personally, I believe that all northstar powered caddies from 93-03 are destined to HG failure eventually. So I would change the head gaskets if I were in your shoes and had the money. To remove the tranny, it's easiest to remove the engine first or the whole engine/transaxle combo together. I don't know about the pricing on the halfcase seal because I've never had to do that job.
  17. #15
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by Krashed989 View Post
    That's what I'm sayin' - an almost inevitable problem, and it's not a hard job to avoid a future chore.
  18. Remove Advertisements
