Northstar powered trike
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, Northstar powered trike in Cadillac Engine Discussion; I am attemping to build a Northstar powered trike , with 99 engine, S-10 2.8 700r4 trans, and Lincoln Mk ...
    Tri-starTrike is offline Cadillac Owners Member
    Automobile(s): Northstar Powered Trike
    Dec 2009
    jacksonville, Fl
    12
    I am attemping to build a Northstar powered trike , with 99 engine, S-10 2.8 700r4 trans, and Lincoln Mk VIII irs, with my own a-arms. i have modded the trans and will use a 4x4 out put and no tail housing, since speedo will run off of front wheel. i have a wiring harness and pcm, but not sure what year. Two motors and w/h were gave to me and I just want to run the motor. Could use the help and ideas of any that are interested.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    Re: Northstar powered trike
    I think I would keep the transverse setup and run that instead to be honest, it should be a lot more compact.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Did you see the one in Hot Rod magazine?
    Dec 2009
    jacksonville, Fl
    12
    97 Eldo.....why take the easy way out and I like to build with what I have .....most of the parts have been free and I don't want it to be a transverse motor.......thanks anyway.
    zonie ....no .....There have been a lot of issues of Hot Rod, which issue.........I have seen most of the N* trikes and I don't want to have a fiberglass bodied barge, like things more mechanical, and just like to build things.
    Here is a mock up picture......Vette IRS, but will use Lincoln Mk VIII, to be able to build a narrow tube frame.
    Dec 2009
    jacksonville, Fl
    12
    Sorry.....forgot to upload pic....lol....
    Mar 2007
    31
    2,618
    So how fast did you want to go?
    Sep 2003
    Arizona
    3,531
    Feb 2010, new issue, pages 24-30. Not exactly what you are building but you will be interested.
    Looks like a good project.
  10. Remove Advertisements
