Misfire on cylinder 6
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Misfire on cylinder 6 in Cadillac Engine Discussion; Hello I am new here and I have am having a problem with my car. I have a 2005 Pontiac ...
    donky4444 is offline Cadillac Owners Member
    Automobile(s): 2005 Bonneville GXP
    Dec 2009
    39
    3
    Hello I am new here and I have am having a problem with my car. I have a 2005 Pontiac Bonneville GXP with the Northstar 4.6 V8 in it. It is misfiring and I had it scanned. The code it is giving says misfire on cylinder 6. Can anybody give me some insight on this issue and also which cylinder is 6? I am guessing that the coil pack has gone bad and needs to be replaced. Any help would be great.
    Thank you.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: Misfire on cylinder 6
    The front bank is 2,4,6,8, left to right. If you pull the coil cassette you may find a bit of oil in the plug wells. Normal - the wells are sealed by cam cover O-rings and they tend to weep. BUT, check all the plug boots for carbon tracks - if a boot or plug is tracked there will be a black stripe down the side of the plug. Y ou must replace the boot(s) in this case.
    www.rockauto.com, your car/year, Ignition, coil cassettes, ICM, wires/boots (some of the later listings put the boots under "wires", an incorrect file.)
    68
    81,887
    If you find it carbon tracked, be sure to replace the plug as well or it will still misfire and carbon track the new boot.
