Race Caddy losing coolant and making noise
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Race Caddy losing coolant and making noise in Cadillac Engine Discussion; Just got a call from the guy where the car was dropped off. The caddy he says is making some ...
    bigds01 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Seville SLS
    Nov 2009
    137
    Just got a call from the guy where the car was dropped off. The caddy he says is making some sort of noise on the far right side (standing at bumper) of the engine, and it is leaking coolant. Is it possible that the water pump just went kaboom?
    68
    81,913
    Re: Race Caddy losing coolant and making noise
    That's where the water pump is.
    Nov 2009
    137
    I think we are going to stud the engine whether it needs it or not (assuming it does) so when we drop it we will replace the water pump and thermostat as well.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,875
    Water pump or 3-rib pump belt tensioner. Keep the OEM thermostat because all the engine controls are set to operate around the design coolant temperature : about 200 degrees at 16 psi.
    The OEM thermostat starts at 188 and is fully open at 206.
  7. Remove Advertisements
