98 N* engine, blue valve cover washers? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Northstar Engines and System Technical Discussion Discussion, 98 N* engine, blue valve cover washers? in Cadillac Engine Discussion; seems to run fine, has more power than my sts but the sts desnt run right.... rides smooth as hell, ...
  1. #16
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    40
    718
    Re: 98 N* engine, blue valve cover washers?
    seems to run fine, has more power than my sts but the sts desnt run right.... rides smooth as hell, hewasnt lying about all the suspension work and stuff.
    Battery isnt charging. Alternator is 8 months old but not charging. Battery light was on so i had a look at wiring, the signal wire to the alt was cut and re-taped together so i put some new wire in and used heat-shrink and wrapped it up good in tape. Light is out now but still says battery no charge so im pulling the alt to have it tested. Other than that the car seems fine, just one of the wheel speed sensors is not working which is weird cause he said he replaced both back bearings and i know its the back not working
    Could be cause the car sat since march, but so far looks like it'll be my winter beater.
  2. #17
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    nice buy man! good find
  3. Remove Advertisements
