Today's Racing Question: Studs or Norm's? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Northstar Engines and System Technical Discussion Discussion, Today's Racing Question: Studs or Norm's? in Cadillac Engine Discussion; nice! i have 67, cars, boats, and toys Originally Posted by submariner409 Post #12: You know how macho your are ...
  1. #16
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    Re: Today's Racing Question: Studs or Norm's?
    nice!
    Quote Originally Posted by submariner409 View Post
    Post #12: You know how macho your are by counting the number of cylinders you own - everything from the Cadillac to the log splitter and leaf blowers.
    I have 43.
  2. #17
    Douglass Harroun is offline Cadillac Owners Fanatic
    Automobile(s): 1998 STS
    Jan 2004
    Seattle
    120
    I believe studs are better for this motor. We have a Cad dealer tech who tells about insert failures he has seen. Do a search on the forum. We haven't heard of studs failing yet. I wonder how many thousands of inserts have been done and what the failure percent is.
    Doug
  3. #18
    STSS is offline Cadillac Owners Enthusiast
    Automobile(s): '03 STS 122K, '01 STS 161K - 3/3/11
    Apr 2008
    Grafton, Ohio
    32
    671
    I have 43.
    The more I learn about you Sub, the more I want to grow up to be just like you.
    I'm up to 26.... looking for 8 more (with blown HGs)
  5. #19
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,816
    Just like my Navy career: 26 years of undetected crime.......
  6. #20
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    I think installation procedures are much more critical on the inserts. If you get an inexperienced tech who just wants to finish the job in a hurry you get a pretty high failure rate. If you get Submariner409 doing them all you would have a fairly low failure rate.
    Saying that, I think the studs are a stronger fix with a lower failure rate.
  7. #21
    IXSLR8 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    69
    You can use studs with Norms inserts. I installed ARP studs and used Norms inserts before I knew about Jake's studs.
    I like the idea of using less parts when it comes to holding down the heads...so the one piece stud idea is a nice idea.
    I'm also using Cometic head gaskets and Hylomar sealer and have found it to work just fine.
    But both stud approaches seem to work fine and are significantly better than head bolts from what I understand.
  8. #22
    Mar 2007
    1,914
    Oh really? i had no idea!. why would you want to use Norms anyway considering the Studs are out on the market?
    Quote Originally Posted by IXSLR8 View Post
  9. #23
    Feb 2006
    56,816
    The ARP stud in a Norm's Insert has been around for years. It is only a slightly less elegant solution than Jakes studs.
    One of the (very distinct) advantages of studs is that they have a fine machine thread at the top (coarse thread in the block) so nut torque and precision clamp pressures are easier to obtain. You don't torque a stud into the block - just past finger tight is enough.
  10. #24
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,658
    Quote Originally Posted by eyekandyboats.inc View Post
    Why would you want to use Norms anyway considering the Studs are out on the market?
    Without getting into a debate over the pros and cons of Jake's studs vs. Norm's inserts. Norm's can be used with the engine still in the car. Jake's studs require the engine to be removed.
  11. #25
    bigds01 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Seville SLS
    Nov 2009
    137
    Quote Originally Posted by 00 Deville View Post
    Wow, I didn't know that Norm's can be done with the engine in the car. I thought the big deal with the caddy's was you had to drop the engine to do the hg replacement.
    Is it true that you dont have to drop the engine to use norm's serts?
  12. #26
    Feb 2006
    56,816
    For inserts you don't have to drop the cradle, but your work and life will be much simpler if you do. To do a good, precise insert machining job with the engine in the car there are a few twists and tricks to use, such as a slight rotation of the entire engine assembly in order to get clearance to install the drill jig and drill and tap the rear lower line of head bolt holes. It is not easy, and if you don't have a calibrated mechanics eye and experience with precision drilling and tapping, you're much safer to drop the cradle. An insert job in the car is not for the faint of heart. Mike Lawson over in Kentucky does his work in the car, but he's been at it a while and has the tools..............
  13. #27
    00 Deville's Avatar
    Mar 2004
    Wilmington, NC
    52
    2,658
    Quote Originally Posted by bigds01 View Post
    There has been several debates over what method is the best or easiest.... most people do drop the engine out the bottom to do the HG repair. Jake pulls the engine out the top... Mike Lawson and a couple others on this forum have done it in the car. Videos of Mike doing one in the car are available on his website.
    http://cadillacspecialties.com/gallery.html
    I do agree with Sub that dropping the cradle is probably the easiest way for most people. Both Mike and Jake have done many of these and have each perfected there own method and personal preferences.
  14. #28
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Personally I don't agree with doing the work in the car. Drilling & tapping creates a mess of aluminum chips. To each his own, but the amount of stuff in the engine bay you have to work around with a drill and tap, makes it difficult. The best way is with the cradle dropped or the engine out. Or both. Block taped up, no engine parts laying around, nothing getting in holes such as the transmission vent tube or alternator, A/C lines, power steering lines, etc...
    Mike is careful, I know.
    But still. Doing the work with the engine in the car still allows you NO access to the block seals/oil pan seals. How many cars need the bottom engine re-sealed? I do this on every car. Who wants to do a head gasket job and then have to pull the engine again 6 months later to do the lower seals... So many of the ones I see need it done. The odd time I'll find a car who's already had the engine re-sealed by a dealer. The one STS, they used so much RTV that there were strips of it in the oil pump pick-up.
    I didn't re-seal the block on my '98 when I did the HG's. Guess what- it's coming out again. It's leaking enough that I can see smoke under the hood when I come to a stop...
  15. Remove Advertisements
