how do i change my idle
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, how do i change my idle in Cadillac Engine Discussion; My car is idling a bit low i feel. is there a way to bring the idle up mechanicly? adjust ...
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    adjust something on the throttle body?
    2001 DTS BTW
    thanks taylor-
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,121
    Re: how do i change my idle
    Supposed to idle at 625 - 675 in D. 1/8" above the 500 rpm tick.
    Nothing mechanical because idle is controlled by the IAC valve, that black/silver canister on the front side of the throttlebody. Remove it carefully (2 Philips screws) and clean the tip with throttlebody cleaner. A new one is around $275, so tread lightly.................
    69
    82,376
    No..
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,658
    Quote Originally Posted by submariner409 View Post
    I would stay away from or be extremely careful using throttle body cleaner on the IAC valve... if it gets inside the IAC valve it will eat the insulation off the windings causing it to fail. It's much safer to use an electrical contact cleaner.
    Also...
    - don't attempt to push the plunger in or it may strip the teeth off the worm drive.
    - be careful with the IAC valve gasket... list price is $31 for a gasket the size of a dime.
    Mar 2007
    1,914
    thanks guys!. it runs about a hair over the 500 rpm mark.
    i will just live with it i guess,
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    Did you try a different IPC? it's possible that the RPMs are fine. id' think RPMs so low would set off a DTC, or the car would stall. Try upping your RPMs and while they're at the correct idle, unplug the IAC (so it freezes in that position). If that solves the riddle, the problem was the IAC... just a thought!
    Mar 2007
    1,914
    why are ther SO MANY OLD THREADS being brought up? wtf?
    and i got my issue fixed.
  10. Remove Advertisements
