head gasket help!!!!!!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, head gasket help!!!!!! in Cadillac Engine Discussion; Believe it or not we replaced the head gaskets on a 4.0 northstar engine. however, we cannot get the timing ...
    lacycosmo is offline Cadillac Owners Member
    Automobile(s): none
    Nov 2009
    49
    3
    Believe it or not we replaced the head gaskets on a 4.0 northstar engine. however, we cannot get the timing chains back on. the tension is too tight. Does anyone know how to adjust the tension? we really dont want to take out the motor. any ideas are appreciated
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: head gasket help!!!!!!
    Well - obviously you need to press the release lever and depress the plunger on the tensioners - are you doing that?
    Automobile(s): none
    Nov 2009
    49
    3
    well i dont know where the plunger is located. sorry this is the first time we have done this all ourselves. We couldnt afford to take it to a shop so we are kinda flying blind here can you help?
    chacenbra is offline Cadillac Owners Member
    Automobile(s): '99 Cadillac DeVille -- '00 Buick Century Millenium Edition
    Oct 2009
    24
    88
    On the side of the motor (opposite the trans) is the timing case, within that case there is a series of guides, sprokets and tensioners when you look at these tensioners you will see a small release lever (as tateos is describing) press that lever towards the tensioner and depress the plunger, now look at the release lever you will see that there is a small hole in the lever place a pin through that hole to keep the plunger from jumping back out.
    Once you get the chains all in place pull that pin and your chains will be tensioned.
    Now one thing that concerns me is you let those tensioners all the way out the plunger may have come out of its socket, if it has REPLACE the tensioners, when I did my job I tried to put one back together and after I got the car all put back together and hit the key I began to hear the chains slapping around, I then had to replace them with the motor in the car (not a fun job AT ALL)
    Note: you will need a 3 Jaw puller to remove the crank damper pully. (there is a special tool that GM uses I believe but a 3 jaw worked great for me)
    MrEldo97 is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Eldorado
    Jun 2009
    65
    136
    After you reset the tensioners and timing chains turn the motor over several times by hand;TDC on compression stroke to TDC on compression stroke (use socket on crank pulley nut to turn) and check to be sure that the timing marks line up. What's the ratio - two crank revs for every cam rev...? It's not just a matter of setting the timing chains once and forgetting them. You MUST assure that you set them properly and the timing doesn't vary - No.1 piston TDC and all timing marks line up.
    Automobile(s): none
    Nov 2009
    49
    3
    thanks we will give it a try
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Guys have done it in the car before but it's the hardest way. The timing cover has to come off and at TDC on #1 the timing marks must all line up. There are threads with diagrams or you can usually get a factory service manual on ebay.
    Did you insert the head bolt holes or use the studs?
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Is the engine in the car? If so, some people have written that they were able to unbolt the timing case cover and slide it back far enough to depress the plungers and avoid removing the crank damper. To remove the damper, I think you will need to drop that side of the cradle down some, to gain access.
    Oct 2009
    24
    88
    I pulled my damper without lowering the cradle in my 99 DeVille.
    bigtone's Avatar
    bigtone is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    545
    I did my H/G in the car, and all I had to do was remove the timing cover bolts. The cover will slide back enough to get in there and retract the tensioners. I used 2 of those orange handled picks that you find at the discount tool place, and I custom bent them to fit in there just right. If I remember, I used a long craftsman screwdriver stuck down though the opening in the head where the chain comes through to push the shoe back while the pick was holding the release lever. While they are retracted, slide the cam gears on the cams. When the engine is at TDC on #1, the marks are exactly 90 degrees perpendicular to the head surface. To double check, after I installed the chains I turned the engine over by hand a few times to make sure the marks were lined up right. Then I spun it with the starter to check the cranking compression. If I was off a tooth, the cranking compression should be off on one bank.
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by bigtone View Post
    I tip my hat to you for your ingenuity and creativity to do this project that way and get it to work. Good job!
    Sep 2003
    Arizona
    3,531
    Bigtone,
    Did you ever write up some of the things that are unique to doing HG's in the car? It's hard to search for a tip like you just gave.
    bigtone's Avatar
    Jun 2003
    545
    Thank you for the compliment. I did start a thread after I finished the job.
    http://www.cadillacforums.com/forums...esert-car.html
    See if that works. I placed a few pics on there too.
    Next, I have to replace the intake plenum on my wife's 01 Deville. Should be a piece of cake after doing the H/G job. My son also has an 01 Deville. Oddly, it is the exact same color, interior and options as my wife's. Needless to say, most of my neighbors wonder about me......
  16. #14
    Sep 2003
    Arizona
    3,531
    I forgot about that! LOL
    You put a good title on it, search should find it.
  17. #15
    mikelawson is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2008
    123
    I use a small allen wrench to hold the tensioners retracted, works perfect.
  18. Remove Advertisements
