Coolant leak 94 Concours
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Coolant leak 94 Concours in Cadillac Engine Discussion; Hi, I have a coolant leak from the rear (firewall) area. Coolant is leaking from between the transmission and the ...
    concours1 is offline Cadillac Owners Member
    Jan 2004
    3
    AngryCoolant leak 94 Concours
    Hi,
    I have a coolant leak from the rear (firewall) area. Coolant is leaking from between the transmission and the block directly above the round type engine support on the bottom centre of the engine.
    The rear head gasket has been replaced, water pump and thermstat.
    What to do?
    Going to try and get lucky with bars leak, but has anyone had a similar leak.
    thanks in advance
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Coolant leak 94 Concours
    You have to try and locate the leak. use an extension mirror.
