Results 1 to 4 of 4
Thread: Bar's Leaks, block seal: Head Gasket Repair ???
    May 2004
    Atlanta, GA
    How you guys doing? Well as most of you already know, i have leaking head gaskets (the headbolts are pulling out of the block) from a head gasket replacement that was improperly done 2 years ago. Well before i attempt to get another head job or engine i wanted to try to see if the Bar's Leak golden seal might work for my car. But i couldnt find it no where, ive looked in wal-mart, advanced auto and autozone. But i did come across another bar's leak product
    Block Seal: Head Gasket Repair 1100
    premium cooling stop leak
    stops block leaks, seals cracked heads, repairs blown head gaskets
    Now this sounds too good to be true, especially in my situation. I couldnt find this product on they website so im assuming its new. Please let me know your inputs on using or not using this product. I dont want to digger myself a deeper hole. Oh yea, i bought it from Advance auto parts for about $8.33
    Thanks in advance, have a blessed day to all
    Sam
    Mar 2004
    Florida
    37
    599
    Re: Bar's Leaks, block seal: Head Gasket Repair ???
    "Bar's Leak golden .. couldnt find it anywhere"
    You can get the same thing from the dealership for $4. Just ask for the cooling supplement .. It's ginger and almond shell. Part number: 3634621
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    If it sounds too good to be true.....it probably IS too good to be true....LOL.
  5. #4
    Jul 2004
    Baton Rouge, Louisiana
    64
    38
    Talk about too good to be true. I cracked a head four years ago on my 88 chevy truck (305) and a small shop mechanic told me about Blue Devil, a liquid that you put in a cold idling engine with the thermostat removed. I tried it because I was on the road a long way from home and in a hurry. In 45 minutes of idling my truck went from pouring water and steam out of the tail pipe to not having used any water in four years. I called them (Blue Devil) and they said that it would not work on Northstars and they didn't know why. They and I were not aware of the head bolt problem at the time. The stuff is amazing!
    Jeffrey
  • You may not post replies
