Results 1 to 8 of 8
Thread: 1993 Cadillac sts 4.6 idle fluctuating
    savage3000 is offline Cadillac Owners Member
    Automobile(s): 1993 STS
    May 2009
    59
    9
    I start my car in the morning idle goes from 1000 to 2500 RPM S I'd tried puting it in gear cannot drive it tell about 20 minutes and it goes back down to normal I replaced the ISC and it still does the same thing can anybody please help me I would like to thank you now for your help.
    69
    82,262
    Re: 1993 Cadillac sts 4.6 idle fluctuating
    Look for a vacuum leak. Maybe around the intake manifold cover.
    May 2009
    59
    9
    Ranger thank you very much for answering my question but I've found what was making my rpm to go up and down it was the gray wire in the plug that plugs into that EGR I've been reading so many of the same symptoms and no one has ever gave this answer. Ranger I believe you are the smartest person on this whole site and most responsible person I wish the rest of the people would follow in your footsteps
  5. #4
    69
    82,262
    Thanks, but you give me FAR more credit than I deserve. There are several people here who probably are more knowledgeable than I.
  6. #5
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    got similiar problem. where is the EGR on these northstars? when you said the gray wire in the plug was bad, was it a vacuum gray wire or an electrical gray wire?
  7. #6
    69
    82,262
    The EGR is to the right of the TB when looking over the drivers side fender. Big black canister with a plug on top.
  8. #7
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    This os on my 94. Your 95 looks the same but without all the plastic stuff over it.
  9. #8
    Feb 2009
    305
    thanks, Ill check it out.
  • You may not post replies
