Code P119
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Code P119 in Cadillac Engine Discussion; Hi. I have a P119 code which explains, to some degree, my performance issues. There is a very slight miss ...
    rsteino is offline Cadillac Owners Member
    Automobile(s): Seville
    Mar 2009
    52
    17
    Code P119
    Hi. I have a P119 code which explains, to some degree, my performance issues. There is a very slight miss at idle which increases to a hesitation/ shimmy upon accelleration. I have read on this forum that this could be due to a clogged or failed injector or maybe damaged insulation on the wires in the injector harness, My question is, is there a way to isolate the issue to the suspect injector rather than a general inspection of all the injectors and wiring? Any help would be greatly appreciated.
    69
    82,266
    Re: Code P119
    First update your profile to include your year. Then pull the DTC's.
