Coolant Supply Line
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Coolant Supply Line in Cadillac Engine Discussion; Is the coolant supply line located by the right passenger side tire?, I took off my tire because I had ...
    Lamar9875 is offline Cadillac Owners Member
    Automobile(s): Eldorado
    Mar 2009
    30
    7
    Coolant Supply Line
    Is the coolant supply line located by the right passenger side tire?, I took off my tire because I had to find a leak and it seem's like there's a metal tubing and rubber tubing connected together and my metal part is leaking, I'll have picture's to show alot better but is there a way to fix this.
    eric007's Avatar
    eric007 is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado Convertible
    May 2005
    Midlands of SC
    54
    19
    Re: Coolant Supply Line
    Hi,
    Did you take a picture yet? I have coolant going somewhere and found some on the passenger tire and on the wheel well, sounds like it maybe the same leak that you have. I hope that's all it is, losing about a 1/4 gallon of coolant a week. TIA!!
    chacenbra is offline Cadillac Owners Member
    Automobile(s): '99 Cadillac DeVille -- '00 Buick Century Millenium Edition
    Oct 2009
    25
    88
    There are 2 metal heater pipes that run along the back of the motor. Hell to change. Check the all the clamps on hoses running to and from the heater core.
    If you do need to change the heater pipes, they are a dealer only item.
