Idles rough after being started in the morning
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Northstar Engines and System Technical Discussion Discussion, Idles rough after being started in the morning in Cadillac Engine Discussion; 1994 STC Over the Summer I have performed several repairs and general maintenance. Water pump replaced, spark plug wires, spark ...
    29Roadster is offline Cadillac Owners Member
    Automobile(s): 1994 Eldorado STC
    Dec 2008
    San Francisco Bay Area
    61
    17
    1994 STC
    Water pump replaced, spark plug wires, spark plugs, two ignition coils, coolant replaced, etc.
    All was running well, until recently when gradually over a couple of weeks time the engine began to run rough after being started in the morning or after setting for more than an hour. It smoothes out after 20 seconds and runs smooth afterwards. I have noticed gas mileage has slipped slightly.
    Any ideas
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,594
    Re: Idles rough after being started in the morning
    What engine ?
    Two ignition coils replaced sounds like early Northstar.
    What wires, plugs, coils ?
    Do some searching for FPR - Fuel Pressure Regulator - for just those symptoms.
    69
    82,173
    Coolant levels and temperatures holding constant?
    Dec 2008
    61
    17
    Temp appears to be holding (198-207) and with the help of a small ruler to check the level it appears to have lowered a little over a 1/4" over the past week or so. But I was losing coolant before the current rough idle appeared.
    V-Eight's Avatar
    V-Eight is offline Cadillac Owners Connoisseur
    Automobile(s): 1991 Sedan Deville
    Mar 2009
    Winnipeg, MB
    26
    2,932
    Has it been getting cold in the morning?
    Dec 2008
    61
    17
    Temps have been in the low 60's at night and low 70's during the day. Perfect really.
    V-Eight's Avatar
    Mar 2009
    Winnipeg, MB
    26
    2,932
    Ok I was gonna say, if it was getting below 0 at night...not sure what that is in F, it could have just needed to warm up. I know my car runs rough for a few mins until it warms up in the winter.
    Dec 2008
    61
    17
    Quote Originally Posted by V-Eight View Post
    That would be 32F and it never gets that cold here, I'm in the San Francisco area. No it idles rough for a short time, then smooths out. I'm guessing it may be either something to do with a censor or in the fuel system. But I'm just guessing.
    Dec 2008
    61
    17
    New info
    I just took the Eldorado out to run a short errand; I noticed that at 45 mph the tach displayed 2000 rpm in overdrive. Then on the way back the tachometer showed the engine running at 3100 rpm while running at 45 mph (72kph)! I got home and parked the car.
    69
    82,173
    Keep a close watch on the coolant level. Rough idle at start up and coolant usage are initial head gasket symptoms.
    Dec 2008
    61
    17
    Any ideas on teh high rpm?
    Trans?
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    High rpm at that speed sounds like your TCC (Torque Converter Clutch) failed to engage. That would usually throw a code. Check the codes by pressing and holding the OFF and warmer (red) buttons at the same time until the whole dashboard lights up (key in the "on" position with or without the engine running). It will then tell you the codes and finish with "PCM?" At that point you can either press the OFF button once again to have it repeat the codes or you can turn the key off to exit diagnostics mode. Post your codes up here and we will help you.
    69
    82,173
    TCC would only raise the RPM by about 200. Not sure what is causing that kind of an RPM increase.
  16. #14
    Feb 2006
    56,594
    Those 45 mph engine speeds look like both a 4th gear engagement/TCC issue.
    The TCC rpm drop upon engagement/disengagement (brake tap) is on the order of 300 rpm +/-.
    4th is one pressure control, TCC is the solenoid, and the 1-2 and 2-3 shifts are a different set of solenoids.
  17. #15
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    hey sub i got a question semi related to the TCC.
    before my TCC went out at 130 Km/h ( 81 mph i think) the rpm was at 2600 or so.
    now that my TCC is gone and i see the slippage. i only see the slippage from any where from 80-120 after that or so. my rpm at 130 km/h is exactly the same!! so i was wondering does the tcc disengauge after a certain speed?
  18. Remove Advertisements
