Tricky Coolant Leak
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Northstar Engines and System Technical Discussion Discussion, Tricky Coolant Leak in Cadillac Engine Discussion; Hrmnn I have a coolant leak and can not find it. I really hope its not the heater core but ...
    brianroark's Avatar
    brianroark is offline Cadillac Owners Fanatic
    Automobile(s): 98 Devil, 93 Deville, 84 Cuttylac built 350 olds, Arctic Cat
    Nov 2003
    Milwaukee, WI
    35
    181
    Tricky Coolant Leak
    Hrmnn I have a coolant leak and can not find it. I really hope its not the heater core but I dont smell coolant in the car... I'm really lost this one, just when you think you know a lot you know nothing. Okay I know what area its coming from but where. I'm thinking its dripping in a different place sliding down a tie rod or something lol, i have no clue..
    The coolant is leaking from the driver side of the car behind the tire. I checked under the car and it apprears to be leaking from the corner of the rear front left fender where the ground effect piece is.
    So the Fender is leaking coolant? WTF?
    it is a slow. Leaks about half of a quart every 2 weeks and its only been 2 weeks. The low coolant indicator only came on once.
    A thing that had me worried which is probably normal but with the head threads corroding on the n*'s is I still had pressure in the coolant resevor after 3 hours of the car being turned off and coolant temp at 110 Degrees.
    I had a poof when i removed the cap which i really hope is coolant pressure and not from the motor. So im thinking i have pressure and a leak. what gives if im leaking it would piss more or alot. I really hope this isnt the heads loosening up.
    brianroark's Avatar
    Nov 2003
    Milwaukee, WI
    35
    181
    Re: Tricky Coolant Leak
    Bump
    anyone?
    69
    82,272
    Don't worry about the heads. Head gaskets almost never leak externally. Pull the splash shield to get a better look at what is leaking.
    brianroark's Avatar
    Nov 2003
    Milwaukee, WI
    35
    181
    What could possibly be in that area, waterpump was replaced about a year ago. Could it be this crossover pipe ive read about.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,830
    Crossover would probably drip somewhere near the engine-transmission joint line. Dripping from the wheel/fender area sounds like the lower hose fitting or the level sensor boss on the surge tank is cracked and the coolant is running down the fender sheet metal.
    Also, take a strong flashlight and look at the firewall coupling for the heater core lines and then trace them back to the water pump/thermostat housing area.
    brianroark's Avatar
    Nov 2003
    Milwaukee, WI
    35
    181
    The leak is coming from the drivers side pretty much where the door meets the fender. on mine the surge tank is on the passengers side. The heater core i think is more on the passengers side thats why im so stumfed. I guess ill have to pull the shield off jack the car way up, get a hand mirror and get down and dirty and find it?? havent really got down and dirty with it yet just shoved my head under and in the engine compartment to take a look. I think its going to be hard to find because its such a slow leak, hasnt really got worse but snow is coming so i cant work on it then,.
    69
    82,272
    That is a VERY strange place to have a coolant leak.
    brianroark's Avatar
    Nov 2003
    Milwaukee, WI
    35
    181
    tell me about it, i have no ideal, there are no coolant passages or anything near it thats why im on here
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    Check the metal heater tubes that run around the rear of the engine from the crossover pipe all the way over to the heater core. They are way down low on the rear of the engine just below the cam cover/head mating surface. They corrode pretty badly over time and leak.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Quote Originally Posted by Mark C View Post
    I second that motion. Very tough to change - some have bypassed them with hoses
    69
    82,272
    I was thinking that as well, but still can't figure out how it would get all the way over to the fender.
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
    Pressurized coolant system?
    brianroark's Avatar
    Nov 2003
    Milwaukee, WI
    35
    181
    Found my slow leak, I pulled the wheel well out, etc and there was a plastic cap in the fender pulled that and water poured out. So it wasn't coolant. MY fender was filed with water and slowly dripping, There was a greasy grime plugging the bottom of the windshield drain passage.
    I think my coolant leak was on the reservoir (auto-bleed) return line, there was a leak down the resevor. VERY SMALL. it was a dry stain, looked like a white crud. I think that could be the prob. I cut the hose down and reclamped it. Still waiting for that damn coolant level low indicator to come back on. Hopefully I fixed it.
  16. #14
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Thank you for the update.
  17. #15
    Jenns90seville is offline Cadillac Owners Member
    Automobile(s): 1999 DeVille d'Elegance
    Amarillo, TX
    21
    I have an odd coolant leak too. Intermittent..but gotten worse lately. coming from backside of engine..midway. whne its leaking..will still have pressure after a while. I finally broke down and got some coolant tabs. Put them in the lower radiator hose today..topped off with Dex-Cool. Prob put about 100 miles on after....dry so far. We'll see.
  18. Remove Advertisements
