Any thoughts on this...
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Northstar Engines and System Technical Discussion Discussion, Any thoughts on this... in Cadillac Engine Discussion; Found this in in my online waste 'o time. Any thoughts? http://www.summitracing.com/parts/TAM-KI-80/...
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    69
    82,268
    Re: Any thoughts on this...
    A fool and his money are soon parted.
    Taspeed's Avatar
    Taspeed is offline Cadillac Owners Member
    Automobile(s): 97 Cadillac SLS
    Jul 2007
    Elwood, IL
    42
    61
    mmkay...seen these things for years. Don't really think they work on most gm's vehicles because of the design of the intake. Anything with a composite intake will be pretty much the same. Waste of money IMO.
    69
    82,268
    They do not work, period. They where invented by someone who believed that P.T. Barnum was right.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,827
    Hey, Ranger..............Remember back in the 50's there was a similar thingy you clamped on the tailpipe to extract more exhaust gas from the engine..........?
    69
    82,268
    Nah, I don't remember that one, but I do remember the Carb spacer that had 2 (or 4) screen strainers that hung down in the manifold. It too was supposed to increase HP and mileage. Also a blue plastic POS that plugged onto the center distributor post and then the center wire went to it. There is always a new one to separate a fool from his money. Sorry to say I have been separated from some on occasion in my younger days.
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,658
    A fool and his money should be parted... I want the mailing list for the people that buy these. I'll come up with some more useless junk to sell them.
    Feb 2006
    56,827
    Someone used to make a 4-bbl carb spacer with little propellers in the bores.........the little propeller axles would wear out and the little propellers would try to get into the nearest intake valve that was open at the split second...................Same theory: Mix up that gasoline !!!
    69
    82,268
    Little propellers.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Quote Originally Posted by the recluse View Post
    Ohh my... that thing spins the air to get it to go into the cylinder easier?... Has that guy heard of centripetal force? It will spin your air into the side-walls of your intake system. The imperfections in the side-walls will slow down the air and reduce your cars power. Have you ever seen a river with a stronger current at the shores?
    69
    82,268
    This crap and it's brethren is not meant for people who have the ability to apply simple knowledge and logic. It is meant for the simple minded who believe everything they read as truth and fact.
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Jun 2009
    Pacific Northwest
    62
    467
    Thumbs downRe: Any thoughts on this...
    I’m surprised they didn’t make the “SAVE THE PLANET” claim. Only $70.00???
    Feb 2006
    56,827
    Don't worry. The Greenies are gullible enough that the scammers will have a field day selling ecologically safe additives. Mark my words.
  16. #14
    mlprus is offline Cadillac Owners Member
    Automobile(s): 2000 SLS-current 2000 STS-REPO'D in '04 :(
    Mar 2009
    31
    I like the "cold air intake" that eliminates the stock airbox that pulls cold air in from OUTSIDE of the vehicle, and replaces it with a shiny chrome pipe with a filter that ends in the engine compartment. I've seen ones on Dodge Neons that pull air from directly above the exhaust manifold. Cold air intake. lol. The ones that actually extend outside the engine compartment might work. But IDK. K&N's don't excite me either.
  17. #15
    Feb 2006
    56,827
    As you posted, our Sevilles already have a perfectly functional cold air intake which gets its air from behind the headlight assembly. It was built that way. Unfortunately we do not have the chrome pipe which is good for at least 20 hp at idle. K&N is very good at advertising. For another tack, take a hard look at the amount of media in a WIX filter for our airbox.
    There are two modifications that you can do to your 2000+ Seville air intake system. They have been extensively covered in here for years. Start searching. Neither modification will result in much more than a feelgood and will create a bit more intake noise for the admiration of a local ricer. (I have done one and it's fun.) Takes two beers, a Dremel tool, and some polyurethane foam to cut/form a gasket at the side of the airbox. Get a flashlight and suss that one out..........
  18. Remove Advertisements
