Heartland High Mileage Oil Changer Review
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Northstar Engines and System Technical Discussion Discussion, Heartland High Mileage Oil Changer Review in Cadillac Engine Discussion; I posted about this product back in August when I needed a top off of oil from SpeeDee. I had ...
    jcresciSTS is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Cadillac Seville STS (November 2012, 183k)
    Jul 2009
    South San Francisco, CA
    29
    968
    I had a problem that my Check Oil Light was coming on at about every 30% of Oil Life lost. SpeeDee the first time it came on it was 1230am after work so I drove to the nearest gas station and bought 3 qts of oil. Put in 2 qts and the light turned off, a few weeks later when I got into my car to head to SpeeDee for an oil change the light came on immediately. I drove down and they changed the oil and said I have a small leak and it was going to cost about $2k for them to repair so I said forget it. Well after that when my car hit the 69% mark the Oil Level came on again and I was only 3 blocks away from SpeeDee so I went for a top off. I told them about the leak and the manager recommended the Heartland product because a lot of their VW customers had success with it. He said it was $25 and to use it every 6months so I said WTH and went for it. He said it is very thick and its supposed to stick to the crankcase and fill up any leaks and what not and also should stop engine tick.
    Now almost a month later and down to 38% Oil Life & my oil is in the middle of the dipstick. I noticed recently that it seems my tick has disappeared too. I'm due for an oil changed in about 150 miles so I'll will know by then if it has truly worked.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: Heartland High Mileage Oil Changer Review
    Well, we know these engines burn a little oil - many leak some also. By thickening your oil, you may be causing more trouble than you are solving. That thicker oil is more viscous than the engine is designed for, and takes longer to pump into all the oil galleries when the engine is first started. Honestly, you probably won't hurt anything in warmer weather, but if you live in a cold climate, you might cause some damage in bitter cold weather.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,909
    "Drove to a gas station and put in 2 quarts of oil......" Sure hope you let it sit for a few minutes and then checked the dipstick. Anything over halfway up the hashmark is over filled................What mileage is "30% of the oil life lost......" on the dipstick. Very possible that it's a considerable distance. NEVER gauge your oil consumption by an oil life monitor: Oil consumption is what a dipstick is for, period. "Life" is a very different parameter from "consumption" - the two have no correlation.
    Jul 2009
    29
    968
    Yeah that is true but I was getting the message about every 1200miles or so and I am over that amount, I change it every 3k no matter what the Life says.
    The guy said during an oil change most of this stuff will come out so that's why they say every 6 months because they figure about every other oil change. I won't put the stuff in the car again and I'll see what happens. Oil Change should be coming up next week.
    68
    81,926
    Not uncommon on a pre 2000 Northstar. The message comes on at 2 qts low, just about when the oil level drops off the end of the dipstick (5 - 5.5 qts remaining).
    Have you read up on oil consumption in the Technical Archives at the top left of this page?
    Feb 2006
    55,909
    If you put 3,000 miles a year on your car, change the oil and filter once a year.
    If you put 8,000 - 12,000 miles a year on your car, a 3,000 mile oil change interval is a waste of oil and money. Your car will safely run 7,500 - 9,000 miles between oil/filter changes.
    Jul 2009
    29
    968
    Got the car in the middle of May and got it changed 1 week later...drove 3k in about 2-2.5 months and changed it.
    So that was about the middle of July the last time I changed it, I should hit 3k in the next 1-2 days. I drive 3k in about 2-3 months. So that's about 12k a year I guess.
    I believe I read that article when I was looking into buying a Caddy but forgot most the information on it. So its normal to have to add oil about every 12-1500 miles? I still have a qt of Castrol GTX in my trunk from when I added it the first time but I'll have to ask SpeeDee what oil they used so I can have that brand on hand.
    I believe I ran it down to 15% when I first got the car and last time I changed it at about 39% because I was just over 3k and I was never religious about changing it in my Buick and Caprice and that lead to problems.
    The system should tell me when to change it but is there a certain number it comes up at?
    Feb 2006
    55,909
    When the OLM determines that the oil/filter is due for a change it will post a message in the DIC. At that point you're supposed to change within a tank or two of gas. Go ahead and use your Castrol for top-up, but remember to only fill to halfway up the dipstick hashmark, cold. That's the full line, not the MAX at the top of the stick. There's a GM Service Bulletin on this - the engine burns off the first half-quart quickly when overfilled, and that leads to oil consumption complaints. 1200-1500 miles per quart is on the low side of acceptable consumption as published by GM/Cadillac. 7.5 quarts of oil with filter is the full mark, not 8 quarts as is common with jiffy oil change shops.
    Curious about your OLM and a lot of driving - the more highway driving I do, the slower the OLM moves down, because highway driving is easier on the engine and oil than urban stop-and-go driving; under city or cold short hop driving conditions the OLM drops fairly fast.
    68
    81,926
    Go to the top left of this page and click on Technical Archives and read up on oil consumption.
    When you get to 10% oil life remaining, the message will appear.
    Jul 2009
    29
    968
    Thanks to both of you guys...I think I'm going to have my mechanic do it next time instead of SpeeDee, that way I can use a WIX filter and make sure its 7.5 qts.
    68
    81,926
    Don't loose any sleep over the 7.5 qts. I only put 7 qts in when I do an oil change just because it's easier.
    Jul 2009
    29
    968
    Actually, you know what I think SpeeDee actually does 7.5, I'm gonna have to check my paperwork again...if they do 8 I'll probably just tell them 7.5.
    32vmonte is offline Cadillac Owners Member
    Automobile(s): none
    Mar 2009
    98
    Quote Originally Posted by submariner409 View Post
    When I pull up a cadillac at work (jiffy lube) it says 7.5 with filter. I start with 7 and go from there to the half way point on the dip stick.
    I also try to tell everyone else there that it has been proven that over half way up the hash marks is over filled and burn off shortly after.
    I can argue it to the death with the rest of the techs at work they still fill ti until it's at the tip top which ends up being about 7.5-7.85 on the digital meter on the gun.
  16. #14
    Jul 2009
    29
    968
    I'm going with my girl's stepdad from now on.
  17. #15
    Automobile(s): none
    Mar 2009
    98
    Quote Originally Posted by jcresciSTS View Post
    Why It won't hurt it people prolly do it everywhere. They obviously do it at speede da de do or w/e the heck you where going to.
    It calls for 7.5 correct. What does 7.5 put it at on the dipstick for the rest of you guys? I have seen it put it to max and on some put the level below half way. Halfway or right under on the cross hatch is ideal obviously and that's where I fill the oil to on the northstar. It's just others that add the half quart too much.
    What we go by at places like jiffy lube is if it's not at the very top of the hash marks ppl will pull there dipstick after they leave and see it's halfway down the crosshatch which is technically safe on any vehicle but mainly they will come back and demand that we top it off the rest of the way (1/4 of a quart most the time) and then procede to say we tryed to not give them all there oil..... The N* is and exception with me and if the customer has a issue with it I give them the facts and they are happy and educated afterwards.
  18. Remove Advertisements
