Ways to increase performance?
Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Northstar Engines and System Technical Discussion Discussion, Ways to increase performance? in Cadillac Engine Discussion; What are some ways to increase engine performance as well as prolonging the life of the Northstar engine? I like ...
    Skiller.'s Avatar
    Skiller. is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    What are some ways to increase engine performance as well as prolonging the life of the Northstar engine? I like to treat my car to as many jewels as I do my girlfriend
    Possibly a Corsa exhaust?
    69
    82,287
    Re: Ways to increase performance?
    This has been discussed AKA beaten to death, many times. There is precious little you can do. GM did it all for you.
    Just maintain it. Change the oil and coolant when or before you are supposed to.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Owner of Northstar Performance
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    The Great White North
    31
    2,600
    Ranger's right. GM did a great job. But for us hard-headed, overly stubborn lead foots,
    I received the reground camshafts from CHRFAB now. I'm crazy enough to install them without being able to tune the PCM just to see the results. I'm expecting a bit of a choppy idle, a very mild one, but I just don't know how she's going to run. I don't know if I'll be able to improve the power any but I'm going to give it a shot. I'll post the results when I get it done.
    69
    82,287
    Or you could add Oxytane to your fuel.
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Hahaha, no thanks!
    I'll just replace my current FRAM air filter with a K&N air filter.
    Edahall's Avatar
    Edahall is offline Cadillac Owners Enthusiast
    Automobile(s): 93 & 88 Allante, 88 Eldorado
    Jan 2004
    778
    Quote Originally Posted by Skiller. View Post
    Hahaha, no thanks!
    Sorry to say, but the K&N air filter will do more harm than good. There will be no increase in power and it'll let more dirt into your engine which will greatly increase wear.
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Really? Wow, I've never heard of that.. So I'm guessing with the increased air flow comes the increased dirt flow?
    69
    82,287
    Yup. Do a search. It's been discussed and tests have been run to show that they pass more dirt. That said, the Northstar air filter is not restrictive at all. You won't get any increase in performance even if you run NO air filter.
    Skiller.'s Avatar
    Automobile(s): NONE
    Sep 2009
    Buffalo, NY
    27
    2,027
    Ah! Good to know!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Google "knize family oil filter study" and get to Russel Knize' Minimopar site. (It's NOT a Mopar site......) and wade through his work on what's in, who makes, and what they look like oil filters. Very enlightening.
    Next time you're in a parts store, take a look at the construction and media area (pleat count) in several brands of panel air filter for your car.
    I personally like WIX products, but that's like engine oils: everyone has their favorite.
    K&N markets quite a line of products, expensive, well built, BUT I would be very leery of using an oiled panel filter in your intake system with the problems of vapor contamination of the Mass AirFlow (MAF) sensor. When you oil a filter, a little is good, more is better, right ? And you can buy a lot of paper filters for the price of one K&N, regardless of how their skewed advertising prices 1,000,000 miles of filters. Snake oil again.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Lets see
    You can change gear ratio. Need the PCM recalibrated for that
    Change the Cams. Need the PCM recalibrated for that
    Change the injectors. Need the PCM recalibrated for that
    CAI. Need the PCM recalibrated for that
    Port the heads. That gives you nothin
    Corsa. Hmmmm
    Remove BTM (Brake Torque Management) Need the PCM recalibrated for that
    Reset the Stoich for E10. This is a huge gain. Need the PCM recalibrated for that
    Change the PE delay. Need the PCM recalibrated for that
    Lets see. Nothin with out me and I am to tiered to do it any more.
    I tried to give out some info, but I haven't heard back
    Feb 2006
    56,884
    AJ, you dirtball: you know too much..................!!
    "Tired, turkey, tired !
    GizmoQ's Avatar
    GizmoQ is offline The Last Good Gremlin
    Automobile(s): 06 XLR-V and 96 Eldorado ESC-V -- One day ;)
    Mar 2007
    St Louis, MO
    2,653
    Quote Originally Posted by AJxtcman View Post
    Lets see
    Corsa. Hmmmm
    Tired my ass, wait till you see what I got for you to work on!!!
  16. #14
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    According to tests performed around here there is no increased air flow. The factory and most other panel filters already flow far more air than the N* can swallow so there's no point.
    If it didn't look so cool I'd take my Volant box off and put the factory intake back on but it's really a clean look and less under hood clutter with the Volant.
    The Volant intake and Corsa exhaust are both GM approved and will not void any warranties or anything like that.
    AJ; I'm willing to listen and I will put some faith in the Corsa, I dropped .2 sec off my ET compared to a previous run. Some of that may be me, the car or whatever but after the Corsa went on I ran the best times yet.
    Do I need to get a new PCM from you calibrated with the most recent knowledge? Talk to me, call me if you have to. I want 14's damn it.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
  17. #15
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    40
    718
    actualy ive wondered a bit myself about the stock filter/breather since i've had a good look at it. Seems the intake air passes right over and through the PCM box. Just how hot does that PCM shell get? Does it heat the intake air? is it supposed to heat the air? I always thought cold air was a good thing?
  18. Remove Advertisements
