98 Eldorado Starting Problems
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, 98 Eldorado Starting Problems in Cadillac Engine Discussion; I bought an Eldorado a few days ago and its having problems starting, in the mornings it takes up to ...
    jreldo is offline Cadillac Owners Member
    Automobile(s): 98 Eldorado
    Sep 2009
    1
    I bought an Eldorado a few days ago and its having problems starting, in the mornings it takes up to thirty seconds before it starts, but starts right up if I turn off the car and immediately restart it. Throughout the day I have the same problem, just not as bad as the first time I start it. I would appreciate any imput you guys might have as to what might be causing this.
    thanks.
    69
    82,287
    Re: 98 Eldorado Starting Problems
    Put your eat to the open fuel filler pipe and have someone turn the key on (no crank). Do you hear the pump run for 2-3 seconds? If not, check the relay. If you do, check the fuel pressure.
