catalyst converter replaced
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, catalyst converter replaced in Cadillac Engine Discussion; I recently had my catalyst converter clog up on me. I got it replaced but the shop said that the ...
    myboneyard's Avatar
    myboneyard is offline Cadillac Owners Member
    Automobile(s): 2000 DTS
    Aug 2006
    65
    I got it replaced but the shop said that the cause was to much fuel being dumped into the motor . He couldn't tell me what was causing it . So my question is has anyone had this issue or know what it may be?
    myboneyard's Avatar
    Aug 2006
    65
    Re: catalyst converter replaced
    No thoughts?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,854
    You need to read the sticky thread up in the top of this main page, titled "How to pull codes". Learn to get any Diagnostic Trouble Codes from your car's built-in system - you don't need an aftermarket scanner. You want the link to OBD-II ("obd2") OnBoard Diagnostics Protocol II. If you have no PCM codes (there are P, B, U, and C codes) then you have no fueling problems, and BTW, fuel problems will usually turn on the Service Engine Soon light.
    "Too much fuel" can range from a stuck injector to a bad air filter to a faulty Fuel Pressure Regulator (FPR).
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    There is no way for him to know what caused the cat to fail.
    It could be something that happened 4 years ago that damaged the cat and then got worse over time.
    If the engine is running badly now then get it fixed. If it runs fine and no other codes are set, live your life.
    If the fuel consumption is abnormal it will pretty much set a code and turn on the MIL. Do you have any other driveability issues or a MIL on (CEL)?
    myboneyard's Avatar
    Aug 2006
    65
    My engine light was on.
    My car had lost all power and would not go over 20. I was told the converter was clogged up, so after changing it the service tech stated that there was plenty of black soot in my tail pipe and that the fuel was running to rich. I did pull the codes before getting the converter replaced . I will pull them again and research to see if i received so type of fuel code. I will also post them here for a little help if possible.The enginge light is no longer on.
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Fuel is a complex Hydro-Carbon.
    Carbon is a byproduct of combustion.
    Everyone's tail pipe is full of soot, whether they are running good or not.
    Codes are the real key.
    Keep an eye on it but don't get crazy.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    If you still feel a loss of power, check to make sure all plugs are firing correctly. I would advise to change your ignition coils, even only as preventative maintenance. But from what you're describing, you may have had severe afterburn.
    Like Ewill says, there's no way he would have known.
    Is the car running good now, and does it have great throttle response?
    myboneyard's Avatar
    Aug 2006
    65
    The throttle response is great.
    i have not had any problems , but it has only been one day .
  11. Remove Advertisements
