01 deville o2's locations?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 01 deville o2's locations? in Cadillac Engine Discussion; I tried doing a search,but came up with nothing.I need to know were the o2 sensors are located.Its a 01 ...
    robz is offline Cadillac Owners Member
    Automobile(s): 01 cadillac
    Jun 2009
    5
    Question01 deville o2's locations?
    I tried doing a search,but came up with nothing.I need to know were the o2 sensors are located.Its a 01 deville NS 4.6.Thanks
    68
    81,729
    Re: 01 deville o2's locations?
    One on each exhaust manifold and one after the CAT.
    Jun 2009
    5
    thanks
  5. #4
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,518
    Try these................Hope you have small hands, crow's foot wrenches, and patience. And DO NOT twist any of the wiring harnesses.
  6. #5
    68
    81,729
    Oh yeah, you'll need a "special" O2 sensor socket. It's basically a deep well socket with a slot milled in the side.
  7. #6
    Jun 2009
    5
    Thanks,Have a question so the bank 1 sensor 1 is the one close to the firewall right?The other 2 are easy,but the one close to the firewall seems hard.
  8. #7
    Feb 2006
    55,518
    What code are you getting that makes you think an O2 sensor is bad ?? Many times, a vacuum leak will trigger a sensor efficiency or "bank lean" code. The Northstar O2 sensors are usually problem-free themselves. Not saying that is your case, but post the codes so we can dig deeper and maybe save you some time and money.
    Yes, right bank sensor is B1 S1. Look at the picture title line.
  9. Remove Advertisements
