Exchange fluids how often?
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Exchange fluids how often? in Cadillac Engine Discussion; I have a 2000 STS I've owned for 5 years, currently has 140K miles. Still has original coolant, brake fluid, ...
    SmoothTS is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    72
    I have a 2000 STS I've owned for 5 years, currently has 140K miles. Still has original coolant, brake fluid, transmission fluid. How often should these be changed?
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    51
    2,659
    Re: Exchange fluids how often?
    Quote Originally Posted by SmoothTS View Post
    I'm sure that you will get some differing opinions on this one... My anal opinion is
    Coolant- Change every 2 years
    Brake Fluid- Change every 50,000 miles
    Transmission Fluid- Go by the life monitor in your car if it doesn't say change it by 100,000 miles change it anyway.
    You are way overdue on a coolant change with the history the the N* has with the corrosion on the head gasket bolt holes you would be a fool to follow the GM recommended change times on DexCool.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,577
    Basically you're way overdue for coolant, and overdue for both brake fluid and transmission fluid.
    This time, take it to a dealer and cough up the money for a "Fall Special" package if one is offered. The entire coolant charge gets changed, brake system gets flushed and refilled, and the transmission gets the new DEXRON-VI synthetic fluid.
    Not cheap, but you will have the peace of mind that its done correctly as well as have a dealer work warranty and someone to fall back on if something's not right, and a complete coolant, brake fluid, and transmission fluid change is no fun in your driveway.
    Coolant: 3-4 years
    Brake fluid: 4-5 years (its hygroscopic and absorbs moisture)
    Transmission fluid: 5 years/100,000 miles or so
