Water Pump Issue
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Northstar Engines and System Technical Discussion Discussion, Water Pump Issue in Cadillac Engine Discussion; Hey guys, I just like to know if I need to change my water pump or not. I have a ...
    thewireman* is offline Cadillac Owners Fanatic
    Automobile(s): 99 Cadillac Deville
    Feb 2008
    Paw Paw, MI
    139
    Water Pump Issue
    Hey guys,
    I just like to know if I need to change my water pump or not. I have a bad leak around the pump area but the pump it self spins fine and the belt is just fine, now I would like to know if I still can use the same pump and replace the old gasket with new? Or I still have to get a new pump? Help me out caddy guys.
    By the way, I have a 1999 Deville, over 140,000 miles with Jakes studs.
    68
    81,916
    Re: Water Pump Issue
    It all depends on where the leak is. If it is the front cover gasket, that is all that needs to be replaced. If it is the rear O ring, likewise. If it is the shaft seal, then the pump needs to be replaced. Usually a leak is from the shaft seal.
    Feb 2008
    Paw Paw, MI
    139
    Great! Thanks, I'll check into it right now...
    Rodney_98's Avatar
    Rodney_98 is offline Cadillac Owners Member
    Automobile(s): 1999 Deville
    Aug 2009
    Central Oregon
    58
    43
    I would also consider the cost of a new pump and the time invested in replacing the gasket if that's all that is needed.
    If the pump is relatively inexpensive and you don't know the history of the old pump I replace it. IMO
    Feb 2008
    Paw Paw, MI
    139
    How many bolts does it have? Something is holding it! Hmmm...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    After removing the water pump cover, the entire water pump capsule comes out using a special socket with tangs to rotate the pump clockwise about a quarter turn and out comes the whole thing; pulley, shaft, and impeller together. Either buy the socket at NAPA (a cheap one will bend and warp) or rent it from something like Auto Zone. You will need a helper to forcibly press the socket against the pump assembly or it will slip. The pump goes back in counterclockwise and make sure you lubricate the seal ring and lock the pump in the correct position.
    A look at the new pump capsule will explain everything..............
    Feb 2008
    Paw Paw, MI
    139
    So, I don't have to take the water Crossover thing off?
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
    No, unless you have a leak from one of the gasketed areas of the crossover itself.
    Water pump replacement - not so difficult. Crossover R&R - a real PITA!
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    No, no, just the water pump cover...
    Feb 2008
    Paw Paw, MI
    139
    Oh man, I should've waited for the answers from you guys because I was trying to take the crossover off! But I tighten the bolts back in and I'm glad I didn't take it off. I got the pump its self off already and the O-ring is gone. Looks like I found my problem. Now last question (I hope) how many gallons of anti-freeze does it take? Thanks!
    68
    81,916
    One gallon of Dex and one gallon of distilled water mixed 50/50 will be more than enough.
    Feb 2008
    Paw Paw, MI
    139
    Got the new gaskets in and put everything back in but when I start the car, it revs SO high.....why?
    68
    81,916
    Make sure everything you unplugged is plugged back in. IAT sensor? MAF sensor? TPS?
  16. #14
    Feb 2008
    Paw Paw, MI
    139
    The sensor on the back head, on the drivers side, is that a knock sensor or something? Looks like I "cracked" the plug....
  17. #15
    Feb 2008
    Paw Paw, MI
    139
    I reset the computer or cleared the codes and it runs a lot less but struggles to idle. Now what happened?
  18. Remove Advertisements
