Stud Kit Help
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, Stud Kit Help in Cadillac Engine Discussion; Hi All, First, let me say that I think the stud kit is the way to go, so this is ...
    olsonscottm is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Jan 2009
    Palmer, Alaska
    76
    Stud Kit Help
    Hi All,
    First, let me say that I think the stud kit is the way to go, so this is by no means a dig on Jake or the stud kit, but me admitting I can't drill worth a damn, evidently.
    I've got the left side of the block drilled and tapped for the stud kit. The problem is, despite my best efforts, the dang things are not perpendicular to the block. The instructions say I can tap them with a rubber mallet, or remove them, put them in a vise, and then hit them to get them "bent" enough to get the gasket and head on.
    How much can one bend these studs? The worst one I have is about a 1/3 diameter off. The rest appear to just be hanging up on the threads.
    I hope I haven't done irreparable harm to my block.
    Thanks - Scott, Palmer, AK
    69
    82,190
    Re: Stud Kit Help
    I take it they don't come with an alignment jig?
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,630
    Re: Stud Kit Help
    Jake's website shows a drill jig plate in the kit.
    Jan 2009
    Palmer, Alaska
    76
    Re: Stud Kit Help
    It comes with an alignment jig, which is how I got as close as I did, but they are still off 1/8" to 3/16" of an inch.
    Just wondering how hard I can "tap" the stud before I crack my block and make a paperweight out of the dang thing.
    Feb 2006
    56,630
    Re: Stud Kit Help
    You need to talk to Jake - I'm antsy about trying to bend a hardened stud into alignment. Better to get your info from the horses' mouth.
    Jan 2009
    Palmer, Alaska
    76
    Re: Stud Kit Help
    That was my first choice, but he's on vacation (well deserved from my previous conversations with him) and won't be back until next week, so I'm told.
    Better to wait and ensure success than force an arbitrary schedule on myself.
    Thanks,
    69
    82,190
    Re: Stud Kit Help
    That is a lot to be off WITH and alignment jig.
    801Hill's Avatar
    801Hill is offline Cadillac Owners Fanatic
    May 2005
    West Valley City, Utah, United
    34
    122
    Re: Stud Kit Help
    I had this exact same problem. Once I finally got all the studs installed, they turned out not exactly parallel. I wasnt sure which studs were crooked and by how much though. I think I had some crooked in one way and others going opposite. Anyway I did try some bending but that seemed scary to me but it worked on the right side but the left side was worse. I was able to either cut the holes in the gasket bigger or drilled them bigger...I cant remember but the gaskets were the easy part. The thing that helped me the most on the left side was drilling some of the holes in the heads bigger. Jake did this with his original design..I believe anyway..because the studs he made at that time were the same diameter all the way up and he would drill out the holes in the heads to accomodate the large diameter stud. So with the smaller diameter studs I still drilled some of the holes in the left head bigger which gave me some more allowance and I was able to slide the head on some of the way. I had to do some pounding as it got tighter and once the studs cleared the holes on the top I put some nuts on it and screwed in the rest of the way down.
    Hopefully this helps because I know how you feel. I am just a grease monkey, not a professional and I was hesitant to do this job but with Jakes help and encouragement I did it and I'm still amazed that I got it all back together and it actually works. I have almost 6000 miles since I did the job and she just runs great. Hopefully it works out for you. Like Sub said it would be good to talk to Jake, he is the master.
    Jan 2009
    Palmer, Alaska
    76
    Re: Stud Kit Help
    I think I've got it. I followed Jake's instructions and tapped on several in the block with increasing force until they lined up. The two studs with the alignment thickness on them I had to remove and hold tight and tap them very hard. I did this three times (remove, hammer, replace), did a test fit with the old head gasket (lining up pretty darn good) and then tried to set the head on. It looks like it should go with just a touch of persuasion, so I'll wait until I have the new head gasket and then try again.
    I appreciate everybody's input, and am especially inspired by pimpdaddycaddy91; 6,000 miles and he did it himself! I hope I've kept everything clean enough. I am afraid of something getting in there and eating up a bearing or something.
    69
    82,190
    Re: Stud Kit Help
    Just keep the Scotchbite out of the work area.
    801Hill's Avatar
    May 2005
    34
    122
    Re: Stud Kit Help
    I was also afraid of getting shavings in the engine. I should have done a better job of masking everything off cause I didnt realize just how much aluminum shavings were created and that they just go EVERYWHERE. I used a shop vac and vacuumed the heck out of it over and over again and I must have got everything. I also changed the oil and filter after only about 50 miles because of the thought of just one or two shavings in the engine and all the dust from being open. So far so good.
  14. Remove Advertisements
