Results 1 to 14 of 14
Thread: Check Coolant Level
    69
    82,284
    Check Coolant Level
    I have done coolant changes at least 3 times on Northstars so it is nothing new to me. I did mine last week. Revved the engine 3 or 4 times to purge the air. Warmed it up and took it out and did 2 WOT runs. Topped it off and figured I was good. Drive to work :40 min., mostly highway and when I go to leave I get the CHECK COOLANT LEVEL message. Get home and sure enough it's a little low. Top it off in the morning. Two days later, the same thing. Checked it again this morning and it was a little low again. :Hmm: No leaks. Only thing I can figure is that I really got some coolant out of it when I reversed the flow of my shop vac and blew it out. I am just amazed that all this highway driving has not purged all the air yet. Where the hell is it hiding? I guess it will stabilize one of these days.
    Sep 2003
    Metro ATL
    4,854
    Re: Check Coolant Level
    The coolant level in the reservoir will certainly stabilize after several thermal cycles. But I would double check whichever hose clamps (if any) you touched during the draining process.
    If you opened the drain plug at the bottom LH corner of the radiator, that might be the source of a small leak that would not be visible from under the hood.
    69
    82,284
    It's certainly been more than a "few" cycles Jim. I did not touch a hose clamp. I used the drain plug and have checked it more than once. Bone dry. I am going in to work tomorrow so I'll see what another cycle does for it. I'm sure it will stabilize. I just have never seen it take so many cycles before.
  5. #4
    Destroyer Guest
    Could it be a H/G issue?
  6. #5
    kckranz's Avatar
    kckranz is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville Base, 2004 Escalade AWD
    Dec 2008
    Raleigh, NC
    42
    275
    Ranger - Same thing happened to me when I replaced my coolant this past spring - took several days of commutes and top-offs to stabilize. In the end it seemed, well I know I put more coolant in than I drained but the level has been consistent since.
  7. #6
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,658
    I have done the shop vac trick on mine also to blow a little more coolant out. I have found that after changing the fluid pumping up the system to 18 psi with a hand pump leak checker will cut down on the top offs required after a fluid change.
  8. #7
    69
    82,284
    What took you so long Destroyer? We expected that comment days ago. If nothing else, you are predictable.
    It has finally stabilized, as I expected it would. I have just never had one take so long.
  9. #8
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Howdy,where did you place the vacuum nozzle when you "blew" it out?,
    how much more do you think you get out of it with the vacuum?.
  10. #9
    69
    82,284
    Put the nozzle in the surge tank filler neck. Hard to say how much more I got out of it, but I don't think it was a significant amount.
    By the way, the level has finally stabilized.
  11. #10
    Nov 2005
    3,013
    Thank you.
  12. #11
    Sep 2003
    Metro ATL
    4,854
    How many thermal cycles do you estimate it took to for the system to settle down; ten? Thirty?
  13. #12
    69
    82,284
    I wish I had counted Jim, but I'd make a guess at 5 maybe. I had to top it off 3 times. I just did my daughters '02 SLS and it seems to have stabilized after a few RPM revs. I don't get it.
  14. #13
    Oct 2005
    Houston
    35
    Any updates Ranger?
  15. #14
    69
    82,284
    It's stabilized now. Took about 3 top offs.
  • You may not post replies
