engine swap
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, engine swap in Cadillac Engine Discussion; I have a 97 STS with a bad motor. I bought a wrecked 99 Deville with low miles on the ...
    GNARLEYSTS is offline Cadillac Owners Member
    Automobile(s): sts
    Jan 2009
    4
    engine swap
    I have a 97 STS with a bad motor. I bought a wrecked 99 Deville with low miles on the engine. Is there any reason this engine wont work in my car? I noticed the 97 engine has a 3-prong male plug on the right side bellhousing flange where the 99 engine does not. Do i need this? Thanks for any help.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: engine swap
    What's bad with your current motor?
    Automobile(s): sts
    Jan 2009
    4
    Re: engine swap
    High miles, 165k, blown head gasket(s). Major leaks. Do you know if the 99 Deville motor is compatible?
    Sep 2003
    Arizona
    3,531
    Re: engine swap
    I do not think so.
    It's been covered before and you might be able to search for it.
    Automobile(s): sts
    Jan 2009
    4
    Re: engine swap
    Thanks, Ive been trying, im kinda new at this...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,909
    Re: engine swap
    Gnarley.........Look at your car's VIN (Vehicle identification Number)......either at the windshield tag or the driver's door sticker. The 8th character is the engine designator......."Y" is the 275 hp/3.11 final drive package and "9" is the 300 hp/3.71 final drive package. They are different in many respects, including engine and transmission electronic controls. An STS must get a VIN "9" replacement engine, and from a year very close to yours. I'll bet the Deville is a VIN "Y". Know that 2000 and up are totally different. No swap.
    If the car is otherwise in fine to mint condition it is worth fixing. Where are you ?? It might be better to ship the car to Jake (97EldoCoupe, www.northstarperformance.com) in Canada and have him stud the block and overhaul it.
    Click on "user cp" up in the blue bar ^^^ and update your login name with your car, year, mileage, location.......it makes diagnoses easier for everyone when we're all on the same page.
    BTW..........Welcome Aboard !!!!!
    Automobile(s): sts
    Jan 2009
    4
    Re: engine swap
    Thank you sub409! Yes my 97 STS is a 9 motor and the other motor i bought is a 99 Y motor. Ive been searching like crazy for info because I was told it would work! The only difference Ive found in the motors is the 3 prong plug by the right side bellhouse flange. The new motor doesnt have it and I cant even find that wire plug on the wire harness on my STS! Grrr....gettin a little frustrated here...but not giving up!
    Destroyer is offline Awaiting Email Confirmation
    Automobile(s): '67 Cutlass,'92 Z28, '12 Crosstour, '12 Cube,00 GMC 4500
    Oct 2003
    Florida
    45
    6,165
    Re: engine swap
    Quote Originally Posted by GNARLEYSTS View Post
    Disposable car that is not worth fixing. Move on.
  11. Remove Advertisements
