Throttle body cleaning question
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Throttle body cleaning question in Cadillac Engine Discussion; Me again (98 STS). I'm not a tech so excuse my stupid question, but I assume that the toothbrush method ...
    Leadergrass is offline Cadillac Owners Member
    Jul 2004
    Toronto, Canada
    11
    QuestionThrottle body cleaning question
    Me again (98 STS). I'm not a tech so excuse my stupid question, but I assume that the toothbrush method involves removing the MAF, and if so, will I need a gasket or can I reuse the old one?
    Thanks.
    97Deville's Avatar
    97Deville is offline Cadillac Owners Member
    Feb 2004
    Ontario, Canada
    56
    Re: Throttle body cleaning question
    68
    81,745
    I can't recall if there is a gasket there or not but if there is you should be able to use the old one. Even if the gasket was damaged and had a small leak it would not make much difference in that position.
