'96 Deville Coolant Change
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, '96 Deville Coolant Change in Cadillac Engine Discussion; Hey guys. It's come time for me to change my coolant in my '96 Deville at 150k+. I have been ...
    386 DeVille is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac Deville
    Oct 2007
    Daytona Beach, FL
    270
    Hey guys. It's come time for me to change my coolant in my '96 Deville at 150k+. I have been researching about using the coolant tablets, however, I am finding conflicting stories. Am I to use the coolant sealant tablets or not?
    On a side note, I have a problem with the oil level warning on the dash when the oil level is fine. Also, the oil pressure light flashes sometimes at idle. Any ideas on these? Anybody know where to get the oil level sensor for a good price?
    69
    82,185
    Re: '96 Deville Coolant Change
    GM quit using the tabs in about '02. So did I. Whether you use then is up to you. No damage will be caused if you don't.
    Sounds like you need an oil level sensor and maybe a pressure switch as well. Check http://www.rockauto.com. Use A/C Delco parts.
    Oct 2007
    Daytona Beach, FL
    270
    Thanks Ranger. I was just telling my fiance, you would be the one to respond.
