Oil in intake manifold 4.6 1993
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Oil in intake manifold 4.6 1993 in Cadillac Engine Discussion; I took the cover off of the manifold there was a coat of oil on everything and the map sensor ...
    savage3000 is offline Cadillac Owners Member
    Automobile(s): 1993 STS
    May 2009
    59
    9
    I took the cover off of the manifold there was a coat of oil on everything and the map sensor was not hooked up to a vacuum line and the fuel regulator was not hookup to a vacuum line can anyone tell me if this is normal and what the problem is if there is one. Wana thank you very much for any help that you can give me Woody
    68
    81,748
    Re: Oil in intake manifold 4.6 1993
    It is completely normal.
    No vacuum lines are needed because the FPR and MAP sensor are inside the manifold and thus subjected to manifold vacuum.
    The grungy oil is a combination of crankcase gases from the PCV valve and exhaust gases from the EGR valve.
    May 2009
    59
    9
    thank you very much for the help
