Sucessful Northstar head gasket repair in a bottle - Page 11
Page 11 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 151 to 165 of 250
Like Tree34Likes
Northstar Engines and System Technical Discussion Discussion, Sucessful Northstar head gasket repair in a bottle in Cadillac Engine Discussion; I know for a fact that the 10 northstars that I have worked on with bad headgaskets that NO Snake ...
  1. #151
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    49
    502
    I know for a fact that the 10 northstars that I have worked on with bad headgaskets that NO Snake oil would have cured
    04GrandAmGT likes this.
  2. #152
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Sucessful Northstar head gasket repair in a bottle
    Bianca just had her HG's fail
    no bolts had pulled out
    just the gasket compromised mainly around one cylinder
    i didn't want to take the chance on putting some sealer in her just in case the bolts pulled down the road
    so we pulled the motor and inserted the block and put some bigserts in there
    she's all back together now and getting a test drive overnight and she'll be home tomorrow
    it has been nice driving a '13 cts in the meantime but i do miss her plush blue leather seats
    the cts is a bit cramped like a cockpit ... my only complaint
  3. #153
    Jul 2010
    Central, NY
    49
    502
    Chris was it #1 that failed that's the main one I have seen, you did your self and the mechanic a favor by not using that stuff. I have had only three northstars that showed alum. on bolts when taken out. I have one apart now that they put the miracle juice in and let me tell you its nasty in there. I believe that alot of these failures are a lack of cooling system maintenance
  5. #154
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,873
    Did they reseal her?
  6. #155
    Sep 2007
    Wilmington, NC
    13,986
    yeah, actually 1 and 3 were compromised and 5 was starting to go
    the plugs looked fine though
    was running rough after startup for the first minute or so of running for a few weeks and then began to hydro-lock at startup for the last few days before i pulled her off the road
    my coolant was just recently changed out (radiator went this winter)
    had probably been 3-4 years since the last coolant change
    the new radiator leaked and was replaced a month or so ago
    then the water pump leaked and i got a new pump and the new cover design
    then almost immediately the rough startup began
    now i just need to fix the elc compressor ... gonna frankenstein mine with another off a car that has a bad exhaust valve
    my elc compressor lost compression and doesn't move any air the vac lines were totally crumbled too
    Quote Originally Posted by vincentm View Post
    did not do the lower block seals as that would cost quite a bit more and we have a technique to do them with the engine in the car so it's not really saving any labor to do them now
    it doesn't drip anyway ... if it did drip then i would have had them do the reseal job
  7. #156
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 Honda Accord LX. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    27
    3,718
    I was actually down there a few weeks ago doing a dealer trade on a GMC Terrain at Bob King and drove through the lot. Lots of inventory down there and saw a beautiful WD '13 CTS-V Glad to hear the car has been fixed and will be back on the road soon!
  8. #157
    Sep 2007
    Wilmington, NC
    13,986
    yeah that '13 WD w/ black chrome grille and red calipers was a special order that the owner backed out of... we kept the deposit naturally ... it's been sitting for a few months as you might imagine
  9. #158
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    688
    I'd like to know that technique :-)
  10. #159
    Apr 2007
    New Bern, NC
    27
    3,718
    Gorgeous car. We dont stock V's as they sit too long on the lot before we sell them. I can't remeber the last time we had one.
  11. #160
    Sep 2007
    Wilmington, NC
    13,986
    Quote Originally Posted by Caddy-EaRL View Post
    i don't know the whole process but it involves suspending the engine from above, dropping the cradle and somehow getting the exhaust pipe out of the way
    Quote Originally Posted by ryannel2003 View Post
    yup
  12. #161
    ksmay71 is offline Cadillac Owners Member
    Automobile(s): 2000 Seville SLS
    Jun 2012
    29
    37
    Yep. Just passed 3,000 miles since my fix-in-a-can. We've moved to Mesa, AZ and we've had days over 115 with me idling in the heat and repeatedly accelerating to 40 mph and then stopping. I don't get it, but it's not giving up.
  13. #162
    Sep 2007
    Wilmington, NC
    13,986
    the only way that a fix in a can will work on these cars is if the gasket itself is compromised ... if the bolts are pulling out the fix in a can will not work because the head keeps moving away from the block with every combustion event creating a gap that gets worse and worse
  14. #163
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,634
    That uses the GM special "engine support fixture" J-28467B and the companion brackets and lift adapter. You basically install lift brackets, erect a T-shaped special brace and hangers over the engine, take out the slack, and then remove everything from the bottom of the engine - cradle and all.
    BUT - with the support fixture in place any work - any work - is impossible on the top - valve cover - side of the engine.
  15. #164
    Jun 2012
    29
    37
    My mistake, just looked at it again... It's been over 4,000 miles since my fix. Started at 99,934 and now I'm at 104,040. I guess it's just a miracle or something, but it's running like a train.
    BTW, I found the most awesome Cadillac video ever. Go to Youtube and search "White Walls Macklemore." Loved it.
  16. #165
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,581
    Quote Originally Posted by ksmay71 View Post
    if your mechanic-in-a-can "fixed" the head gasket leak - for 4000 miles -
    than you DID NOT actually have a head gasket leak -
    it was simply misdiagnosed - like so many are -
    oh - and about that video - IT SUCKS -
  17. Remove Advertisements
