Air ride compressor
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Air ride compressor in Cadillac Engine Discussion; Hi there, I had just replaced the air ride compressor with a used one, but not it takes kind of ...
    egheorghe is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Deville '98
    Jun 2008
    Chicago
    151
    Air ride compressor
    Hi there,
    I had just replaced the air ride compressor with a used one, but not it takes kind of long for the car to rise to the right level. Do you think it might be something i did wrong or there is a air leak that caused the other compressor to brake and the problem is still there?
    What should I check first? When there is 3 people on the back seat the compressor works for several minutes. Is that normal? Maybe I just pay too much attention to it now.....
    Thanks!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,197
    Re: Air ride compressor
    If the compressor assembly levels the car and shuts off, that's OK. If it cycles on and off, even every 5 minutes, you have a slow leak.
    Actually, it should take no more than 15 - 20 seconds to adjust level.
    Jun 2008
    Chicago
    151
    Thank you!
    Well it brings the car at the right level, but I think it takes too long.
    Do you know if there is a certain pressure that the compressor should pump out air and how/if I can check that?
    AlBundy's Avatar
    AlBundy is offline Cadillac Owners Master
    Automobile(s): 1996 Eldorado Sport Coupe, 2009 Black Navigator
    Jul 2005
    Chicago
    41
    5,023
    Did you check for codes?
    Jun 2008
    Chicago
    151
    No codes
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    The replacement pump could be worn and weak.
    Also, the pump usually wears out as a result of a leak that caused the original compressor to overwork.
    Two possibilities.
    Jun 2008
    Chicago
    151
    Thank you guys!
    I'll try to see if there is a leak in the system.
    OOoo, another question: Is it possible that the shocks are loosing air or just the air lines?
    Feb 2006
    56,197
    Use the tried and true technique of getting the car up on a lift, start the engine and level the car. Shut down and spray a soap solution over the shocks and lines. Bubbles ??? Leak. You may have to trace the problem all the way back to the compressor connector.
  11. Remove Advertisements
