Blew the head gaskets replacing the motor
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Blew the head gaskets replacing the motor in Cadillac Engine Discussion; i have a 1996 cadillac sls and the cooling system seems to be building pressure and falseboiling so my hg's ...
    chrs550312 is offline Cadillac Owners Member
    Automobile(s): 1996 CadiLLac Sls
    Jun 2009
    In the smokies
    30
    1
    i have a 1996 cadillac sls and the cooling system seems to be building pressure and falseboiling so my hg's blown, heard theres a 50/50 chance that a hg job will work. so i guess my best bet is replacing the motor and any advise would be very helpfull, like am i gonna have to swap any sensors, parts? or should i just try to fix the heads? also my brakes hit the floor now and seems like fp and rd side brakes are working, is it in the wheel hub or master cylinder?
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Re: Blew the head gaskets replacing the motor
    Quote Originally Posted by chrs550312 View Post
    If it's done correctly thers a 100% chance that it will be good for many years.
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,621
    Visit my website at www.northstarperformance.com - I have a 100% success rate on replacing HG's on Northstars, over 80 cars to date. 0 Failures.
    If you do the job yourself or get a local shop to do it for you, have them install a set of studs - www.studkit.com - I manufacture, sell, and market these kits, and if you use them your HG job will last. There are GM dealerships/garages ordering these because their "GM approved" inserts are pulling out.
    Just don't replace the engine with another one. You'll likely have double trouble.
