1997 deville stalling at idle
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Northstar Engines and System Technical Discussion Discussion, 1997 deville stalling at idle in Cadillac Engine Discussion; My 1997 base DeVille had a P0741 code and I thought the stalling at a stoplight was due to the ...
    Rapscallion is offline Cadillac Owners Member
    Automobile(s): 1997 base DeVille, Polo Green
    Apr 2009
    Sheboygan WI
    44
    55
    My 1997 base DeVille had a P0741 code and I thought the stalling at a stoplight was due to the TCC was bad. But mow after the TCC has been replaced I still have the stalling problem. It will stall at a stoplight even when I put it in neutral. Now the car is stalling when I'm moving at very low speeds.
    I searched this forum and found a thread that discussed the IAC motor. I'm looking at the intermittent failure so the motor resistance should be higher than normal...
    My questions are:
    What is the normal resistance measurement?
    and
    Is there anything else I should check?
    As of right now I have no current codes.
    Thanks in Advance!
    69
    82,159
    Re: 1997 deville stalling at idle
    Do a good TB cleaning first.
    Apr 2009
    Sheboygan WI
    44
    55
    I cleaned the throttle body and IAC motor, but I still get stalling at low RPMs. It doesn't matter if I'm in gear or neutral, it stalls just the same.
    69
    82,159
    Are you sure that the IAC air circuit is clear?
    Apr 2009
    Sheboygan WI
    44
    55
    I'm not sure what you mean by the IAC air circuit. Pardon my ignorance I did replace the IAC motor yesterday and it ran great for the rest of the day - but today at lunch it stalled a couple of times at idle. It did rain this morning, I'm not sure if that is important.
    How do I check the idle air circuit?
    69
    82,159
    The IAC circuit is just an air channel that bypasses the throttle plate and is controlled by the IAC valve. There should be two holes in the inside of the TB. One before the throttle plate and one behind it.
    Apr 2009
    Sheboygan WI
    44
    55
    Thanks,
    I'll pull the IAC off and take another look in there. I cleaned it out the best I could with throttle body cleaner but there still was some black in there. Maybe I'll throw in some seafoam - someone in this forum had some good luck with it.
    69
    82,159
    Ahh, forget the snake oil. All you need is carb or TB cleaner. Scrub it till it is clean. If the IAC circuit is carboned, clean it out and spray the cleaner in there.
    Apr 2009
    Sheboygan WI
    44
    55
    I pulled the IAC off and the parts I see look clean, but I stuck a Qtip in there sprayed with throttle body cleaner and it came out black. I repeated the procedure using over 30 Q tips.... I think I'm going to have to take the throttle body off to get the thing really clean. I'll let you know how it turns out.
    69
    82,159
    Don't go through all that work. Spray the cleaner in and if you see it come out inside the TB bore, then the passage is open.
    Apr 2009
    Sheboygan WI
    44
    55
    Thanks,
    It's open then, but very dirty. After it's clean, what should I look at next if it stalls?
    69
    82,159
    Did you ever verify if the IAC motor was actually working or not? Can you keep it running with your foot on the accelerator?
    gfbphx61 is offline Cadillac Owners Member
    Automobile(s): 1993 elderado
    Jun 2009
    56
    1
    WinkRe: 1997 deville stalling at idle
    i have a 1993 elderado doing the same thing it stalls at 207 degrees at idle shop says its the computer but it's been replaced 3 times and still have the problem any ideas?
  16. #14
    Apr 2009
    Sheboygan WI
    44
    55
    I assume it's working because right after I replaced the IAC the car would almost stall out, and then the car would rev up to about 950 to 1000 rpm, then settle out to about 625 to 650 rpm.
    The car ran ok for a couple of days, but today it stalled 4 times while waiting in line at a drive through.
    The stalls seem to come out of nowhere; meaning there is no warning before they occur. I don't know if the car would stall if I were to give it gas, but I doubt it would. All of the stalls so far have occurred while my foot was off of the gas. And they seem to be more likely after the car has been rained on.
  17. #15
    69
    82,159
    Still no DTC's?
  18. Remove Advertisements
